Hello all.
Im in Australia and have just purchased a 2013 roush raptor of a seller. It has 54000km on it and i have had it for two weeks and just the other day the engine light appeared and within a day the raptor was misfiring and getting worse every drive. I was also towing a 2t machine behind for work. So i managed to get it scanned and the code 3055 for misfire in cylinder 5 coil. So the local mechanic switched what he thinks was cylinder 5 coil with the coil next to it to see if problem followed coil. But i think the cylinder 5 coil is on the passenger side of engine which would be originally driver's side before conversion. So not sure if he switched correct coils in this instance. As when we re scanned it showed same code so either there is issues with that cylinder or he has checked wrong coil. He changed the two front driver's side ones which would have been passenger side originally. If that makes sense. Bottom line the code showed up the same. So being the weekend i checked the plugs myself and found two bottom spark plugs were stuffed so i replaced them with what i think was the equivalent to the original sparks or ngk 6510 . The problem was still there so i did order some ngk 6510 to see if they solve the issue. So not sure if anyone can help for now. It still may be coil pack or else it could be a number of things. Injectors etc. It did get tuned up north where it is much hotter than down here so maybe ute is running leaner and caused an issue. Any help would be appreciated. It will go into mechanic monday for comp test but this was done before purchase and all cylinders were fine
