I had to share how pleased and downright amazed I am at how well this stuff works.
I have used many spray wax products in the past with varying results. The best I had found up to now was the original Meguiar's Quik Detail spray but even that would smear a bit a require more than just a spray on wipe off as advertised. Also, if you tried to apply it to anything but a perfectly dry, cool surface forget about it.
Well, the Carnauba Plus Premium Quik Wax really does just wipe right off, even if your rag is damp due to drips after a wash or in direct sunlight. My hood was almost too hot to touch in direct sunlight and this stuff still wiped right off and left a smooth finish. It seems to almost evaporate after 1-2 passes with a microfiber and shines like a liquid hand wax.
After a week, the water is still beading off my paint and the grime washes right off. I'm telling you for a "quik" shine between waxing you have to try this stuff.
Sent from my DROID X2 using Tapatalk 2
