Forscan = free
OBD2 =$35
1 set of RCA wires tapped in to the the wires going in to the sony amp.
Cut the RCA in 1/2 now you have 4 all ch. RCA price is dependent on quality
You can skip all of the info in
RED. If you do the FORScan mod use the low level // flat EQ signal and just add a amp or two. A DSP or preEQ is not a must. Most of the newer amps have good on board EQ adjustments
You could use a JL Audio Fix-86 DSP @ $ 379 It uses a test CD and sets all EQ for you or us a laptop and edit yourself. or 16-EQG7 - Memphis 7-Band Graphic Equalizer / Preamp @ $139 and set it yourself
Most shops are using JL , Audio Control , or a BIT one with a range of $380 to $1000. and they also leave the Sony amp in because of the NAV and they do not take the time to learn how to remove it.
On top of all of this the shops are not making a change to the ACM. this means that they are sending a hi level clipped signal. Also with out the ACM change the Factory EQ Processing is still there. The Factory EQ Processing reduces the bass as the volume is turned up. The high level is not the problem most amps have Hi level in puts.
The shops use the JL , Audio Control , or a BIT one DSP to try and clean the clipped signal up. So with a new DSP it takes the clipped bass limited signal and tries to interrupt what is missing.
What is a flat response
https://www.youtube.com/watch?v=BLtjjqoHpg0
---------- Post added at 01:05 AM ---------- Previous post was at 12:59 AM ----------
INFO from Crutchfield (not my go to source but some good info)
Your factory stereo uses preset equalization designed to make cheap factory speakers sound better, meaning that it automatically adjusts the different frequencies, creating audio "peaks and valleys" which can degrade sound quality. It is particularly noticeable when you add amplifiers, speakers and subwoofers to your setup, as any deficits in the sound are literally amplified.
Most factory stereos also limit the bass output as volume increases in an attempt to protect the speakers. The trouble is, even if you upgrade your speakers and install an amp and sub-woofer, the bass output is still limited by your factory stereo. This throws your system out of balance and makes the bass sound muddy and weak
