Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford Raptor Lighting Forum [GEN 2]
Does rigid make a “[email protected] bracket?
This is a discussion on Does rigid make a “[email protected] bracket? within the Ford Raptor Lighting Forum [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
Originally Posted by chujk1985 oh, so it does work. Uncas up above was saying it would not work for him. ...
RigidAZ, RigidIndustries
Like Tree7Likes
Old 04-23-2018, 08:44 AM   #11 (permalink)
Uncas's Avatar
Originally Posted by chujk1985 View Post
oh, so it does work. Uncas up above was saying it would not work for him. I will give it a try.
I guess I didn't try hard enough. I will try spinning the bracket around. Nice setup Crooks,
2012 Black Screw 165k from Cape Hatteras to Yellowstone, Key West to the Adirondacks.
2018 Magnetic Screw Bought from Dealer Inventory 2/3
Uncas is offline   Reply With Quote
Old 04-23-2018, 09:30 AM   #12 (permalink)
Installing my rigid fogs with the diode dynamics mounting bracket.
Does anyone know if Rigid makes a “shorter” mounting bracket? When mounted the bumper is covering a small section of the bottom of the fog.
I used the N-Fab brackets for my Rigid radiance cubes. Plenty of adjustability. I'm happy with them because the spacing is very close to perfect but regardless of which way I put them on one corner of the first or the last cube ended up being a little behind the bumper. This is best I could do.
Uncas likes this.
Digger is offline   Reply With Quote
Old 04-23-2018, 10:23 AM   #13 (permalink)
Any luck?
chujk1985 is offline   Reply With Quote
Old 04-23-2018, 01:39 PM   #14 (permalink)
ewm98's Avatar
Junior Member
I was also trying to find a shorter bracket for my lights and came across these.
Rigid Industries 40184 D-Series Black L Bracket Kit with Hardware https://www.amazon.com/dp/B00K87WWRE..._zLH3AbMPMHHK9
2017 Magnetic 802A Supercrew W/ Tech package, Eibach Pro Lift Springs, Method MR301 (Machined)
ewm98 is offline   Reply With Quote
Old 04-23-2018, 03:07 PM   #15 (permalink)
Nick@Apollo-Optics's Avatar
aka etalian2005
Remove the U-bracket, flip it 180* and reinstall. You’ll then be able to use the curved channel to dial in the height perfectly. Hope this helps!
CROOKS, chujk1985 and Uncas like this.
Nick@Apollo-Optics is offline   Reply With Quote
Old 04-23-2018, 06:34 PM   #16 (permalink)
I wish I could find the post on how to make the bracket from some L channel.
CROOKS is offline   Reply With Quote
Old 06-13-2018, 10:31 PM   #17 (permalink)
Junior Member
Flip the bracket and make them as short as you need.. but rigid does make a bracket that will allow you to flip the lights so the logo is correct
Uncas likes this.
handstr is offline   Reply With Quote
Old 06-14-2018, 12:31 AM   #18 (permalink)
Thanks for the info! I am seeing others mounted pretty flush with the bumper cut-out. It seems like there are some shorter brackets out there?
Here's the one I like. They also have a 3 light version. A little pricey, but I like the way it fits.
https://www.cjponyparts.com/dual-fog...2018/p/LBMB35/
Raptorguy1 is online now   Reply With Quote
Old 06-14-2018, 10:46 AM   #19 (permalink)
Same Issue with the D-SS, I talked to Rigid Support and they are passing it on to the engineers since I was the 10th call they have had about this. Email them and we'll see if we can get them moving faster.
https://www.rigidindustries.com/contact-us
Just curious why you chose the DSS for that location? I wouldn't think the side shooters are going to get much light out the sides given they are behind the bumper. I would think the D-XL (with twice as many lumens, all forward facing) would be a good fit for that location (assuming they fit).
I have DSS on my A-pillars and I'm a huge fan of the near field coverage.
My build thread: http://www.fordraptorforum.com/f65/w...6/#post1012544
Truckzor is offline   Reply With Quote
Old 06-14-2018, 11:32 AM   #20 (permalink)
Disregard. I just read further and saw your pics. I see what you're doing now.
Rigid fog light bracket question Digger Ford Raptor Lighting Forum [GEN 2] 70 04-15-2018 10:39 PM
GEN 1 Rigid D2's in a Baja Designs Bracket DHW Ford Raptor Lighting Modifications Forum [GEN 1] 14 11-20-2017 07:06 PM
KC 20 Inch Bar With Rigid Bracket? Aventador22 Ford Raptor Lighting Modifications Forum [GEN 1] 3 06-13-2014 12:57 AM
Help with Rigid Dually / Bracket Mount RaptorScrew Ford Raptor Lighting Modifications Forum [GEN 1] 24 12-09-2013 01:58 AM
Rigid fog bracket fasteners- ADVICE aR4CE Ford Raptor Lighting Modifications Forum [GEN 1] 11 05-24-2013 09:34 AM
