Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford Raptor Lighting Forum [GEN 2]
Chase lights for $30
This is a discussion on Chase lights for $30 within the Ford Raptor Lighting Forum [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
Here in East TN, I don't have the need for a permanent chase light solution. I also wanted to be ...
Like Tree1Likes
  • 1 Post By Kenny008
Old 05-30-2018, 07:13 PM   #1 (permalink)
Default Chase lights for $30
Here in East TN, I don't have the need for a permanent chase light solution. I also wanted to be able to have removable rear-facing white lighting for camping. I don't need an expensive set-up, and I wanted it to be removable. I ended up with a pair of lights that fit VERY snugly in my rear stake pockets. They have removable amber lenses.
I had them out on some moderate backroads / trails. They stayed very firm. Would I take these out west on high-speed desert runs? Maybe, but I wouldn't expect them to necessarily work as well as a for-purpose chase light kit. But for my use, they work well, and the cost was right.
2017 Lightning Blue SCrew, 802a, tech, moonroof, graphics package, beadlock
Kenny008 is offline   Reply With Quote
Old 05-30-2018, 07:32 PM   #2 (permalink)
If you're interested in the parts:
Nilight 18w lights (pair): http://a.co/4K9qOeL $14 for the pair
Amber Lenses: http://a.co/hrtpnxc $7
Connectors: http://a.co/dZlSAVJ $8
Note that the amber lenses did NOT quite fit. I had to heat up the tangs with a heat gun and carefully bend them outward. Used large rubber bands to hold them in place. The lights didn't get hot enough to damage the lenses or the bands. I also drilled a small hole in the lens and used a wire to capture them to the light in case they fell off. They have stayed in place so far.
I used a pressure-treated 2x4, cut to a tight fit, and routed a notch for the power cable. Used 5/16-18 1" long wood nut screwed and glued into the end of the board.
Ran the wire from AUX 6, back the passenger side (inside the frame), and came out right under the stake pockets. Only around 3 amps total, so no relay needed.
Old 05-30-2018, 07:43 PM   #3 (permalink)
I'm a light snob but I appreciate diy. And since half this forum can't even do their own oil chance you get a pat on the back.
"The only good pace is a suicide pace and today is a wonderful day to die"
reaper1441 is offline   Reply With Quote
Old 05-30-2018, 08:01 PM   #4 (permalink)
I'm a little more discerning on my permanent lights :).
reaper1441 likes this.
Tags
chase, chase light, rear lights
WTB: Chase rack for Gen 1 Beardo Want to Buy 3 11-29-2017 01:29 PM
Chase Rack GEN 2 jaredq22 Ford F-150 Raptor General Discussions [GEN 2] 16 06-23-2017 07:13 PM
Chase / Bed Rack Jag Garage Sale 9 06-30-2015 04:53 PM
Looking for a chase rack.. Rapford75 Ford Raptor Exterior Modifications Forum [GEN 1] 18 12-24-2013 05:59 PM
Chase rack. Biggest Want to Buy 17 08-07-2013 08:17 PM
