Air Compress and Tank
Renomaan
My compressor is smaller and has no tank, its instant on as needed for the airbags.
I removed the fender skirt and there is alot of room under there from these flared fenders. I used self tappin screws to secure it to metalwork along the upper area(just on the otherside of where the Upfitter flying leads are).
---------- Post added at 01:35 PM ---------- Previous post was at 01:28 PM ----------
http://www.fordraptorforum.com/f262...g-needs-airbags-53216/index3.html#post1132733
VegasRaptor18
Installed my ARB dual compressor, put the air fitting on the back, SS washer painted black. Did have a 2.5 gallon Viair tank but decided against putting it in. After getting everything installed I realized there is a lot of room under the fender and perhaps I could have mounted the compressor in there opposite the bed. Fits nice though, wired up to aux switch and works well, I plan on only use for airing up tires.
f967b5cbfdd069ca0dfd884e2e465be2.jpg48f1a014122c0208710e5777dbcf5d35.jpg44f7865484b0d14d34cff64475fe1812.jpg00c9975615fc0382a1d8fa5c501c90ad.jpg6cdd08426d629c82614909b054b45725.jpga4ef5e387a750e72c9ffe6b8c52dd1d6.jpg
k-rub
Tucson, AZ
Nice clean install. Looks good. Are you going to leave the tank mounted permanently or take it off when not 4wheelin?
VegasRaptor18
If you are referring to my install I decided to skip the tank, I fabbed up some brackets and SS hardware, was going to mount under the passenger side to the frame but decided against it. Airs up tires just fine without the tank, didn’t want to complicate the install ultimately.
k-rub
Tucson, AZ
Yeah I meant the compressor. Looks great. Hopefully the compressor doesn't get damaged stuff gets put in the bed or when weather rolls in.
