Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford Raptor Suspension Discussion and Modifications Forum [GEN 2]
SVCOFFROAD C.A.S. Coil Adjustment System
This is a discussion on SVCOFFROAD C.A.S. Coil Adjustment System within the Ford Raptor Suspension Discussion and Modifications Forum [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
Originally Posted by BRAPPPP Will this be the same height as mid perch on gen 1 or higher ? Sent ...
Like Tree234Likes
Old 01-18-2017, 02:55 PM   #21 (permalink)
Raptizzle's Avatar
FYT
It's adjustable.
johnjoemd likes this.
Gen 2 Raptor Equipped With:
SVC Offroad
KING Race Shocks
DEAVER Suspension
Raptizzle is offline   Reply With Quote
Old 01-18-2017, 05:35 PM   #22 (permalink)
Junior Member
Originally Posted by svc View Post
Got the measurements done! Making a few small changes , then off to laser!
So have you finished the first prototype and install? I am interested to see the final product and review. Maybe video if you have?
rbh224 is offline   Reply With Quote
Old 01-18-2017, 05:40 PM   #23 (permalink)
Originally Posted by 2014RubyRed View Post
So, any plans to offer this on the existing Gen1 2.5 shocks? Such as great idea though.
Good work!!!
I think this is a great idea. With all the weight I've added to the front end, I'd like to be able to get mine in between the mid/top perch settings.
SOAKINRED likes this.
My build thread: http://www.fordraptorforum.com/f65/w...6/#post1012544
Truckzor is offline   Reply With Quote
Old 01-18-2017, 08:28 PM   #24 (permalink)
SOAKINRED's Avatar
Default Install
With the new 2017 Raptor hitting dealer showrooms we have been hard at work the past few months developing new products, and improving on our current line-up of high performance products for Fords new flagship F-150, the 2017 Raptor. Ford stepped up their game on this truck with offering Fox 3.0 IBP coil-overs as a factory equipment. As great as these are going to be compared to the old 2.5 IBP shocks, Ford took away one of the main things what we all loved about the original, and that's the ability to adjust ride height. Now there is a solution that doesn't just offer you a simple one height fits all adjustment, such as mid or top perch, or a adding a spacer.
SVCOFFROAD has developed a hybrid system known as C.A.S. Coil-Adjustment-System. Our new C.A.S. System will turn your static front coil-over into a direct drop on threaded body coil-over, basically turning it into a true infinite height adjustable Coil-over as found on all aftermarket 3.0 Systems
Our new C.A.S. System will allow the following
- Infinite height adjustment up to original Top Perch height
- Allow for front end corner balancing
- Allow for finite front suspension adjustments to compensate for added weights. EX: if you add a heavy front bumper with a winch, or you add tons of lights, you don't limit yourself to just one height fits all.
- Designed to fit directly over coil-over
- Manufactured in the U.S.A
So now the fun part, we are looking for three willing participants to allow us to install the new C.A.S. (Coil-Adjustment-System) on their new 2017 Raptor.
Thanks.
Do you have any side pics of the truck you installed them on?
SOAKINRED is offline   Reply With Quote
Old 01-18-2017, 09:14 PM   #25 (permalink)
Huck's Avatar
It is adjustable. So you have multiple height adjustments
Icom F5021,RPG Stg 4+ Fox 3.0 coilovers, RPG Tie-rods (modified to camburg hardware), RPG PS reservoir, Camburg 1.25" UCA's , Raptor -Retro fit '13 HIDS, Line-x preminum, Bluewater LED bed lights, Ipad mini navigation. Bubba rope. Rollx, Recon 10.5k winch synth rope, factor 55, SVC Custom acuated tower. Visions 30" xmitter extreme, 35" toyo MT, visionx 6550 spot.
Huck is offline   Reply With Quote
Old 01-19-2017, 11:32 AM   #26 (permalink)
BRAPPPP's Avatar
What's max height without cv binding ?
BRAPPPP is offline   Reply With Quote
Old 01-19-2017, 04:13 PM   #27 (permalink)
Huck's Avatar
since its the same front diff as the Gen1, and same wheel track, i believe it is safe to conclude that its the same axels as Gen1. there for same height limitations,
Old 01-19-2017, 10:59 PM   #28 (permalink)
BRAPPPP's Avatar
So probably mid perch. Maybe in between mid and top like the guys with 3.0s were doing. Mid perch doesn't achieve level but that in between does achieve level. I would like to hear from the guys who are making these collars what is the max height without binding.
Old 01-21-2017, 01:36 PM   #29 (permalink)
Just turned down a set of rpg collars, decision was easy after first installer had to remove the entire shock...
Hoping these parts arnt too far away from being ready to ship.
Im sold so take my money cuz i was ready to slap these on yesterday...
ScorchedEarth is offline   Reply With Quote
Old 01-21-2017, 03:23 PM   #30 (permalink)
sea2jet's Avatar
What makes these different so the shock doesn't have to be removed like the RPG?
2017 Lightning Blue SCAB/802A
sea2jet is offline   Reply With Quote
Which coil for the 5.4L monk99 Ford Raptor Engine Discussion and Performance Mods-5.4 Liter Triton V8 [GEN 1] 11 12-25-2016 11:47 PM
Magnaflow Exhaust cat back system or welded in system? Renegade70 Ford Raptor Exhaust and Cutouts Discussion [GEN 1] 14 09-28-2015 11:08 PM
3.0 coil overs. dfass16 ICON Vehicle Dynamics 3 05-27-2014 01:13 PM
Accel coil packs smarsha11 Ford Raptor Engine Discussion and Performance Mods-6.2 Liter V8 [GEN 1] 2 03-19-2014 03:04 PM
Rear coil suspension whtrapta Ford Raptor Exterior Modifications Forum [GEN 1] 7 09-01-2011 08:00 PM
