ReadyLIFT SST Lift Kit 2-1/2" F-150 Raptor 2017-2018
Tlh235
Looking for opinions from anyone who had this installed(Pros/cons) Also, if you did have it professionally installed, how much did it cost you?
torrin
Nashville, TN
Most here will say why did you buy a Raptor if you wanted a lifted F150? Why do you want to lift it? There may be better ways to accomplish your goals without undermining the suspension system.
WhatExit?
48th state
I don't have it so I can't comment but here's one source for it...
https://www.stage3motorsports.com/66-2755-2017-Raptor-ReadyLift-2-5-Leveling-Kit.html
This source appears to be 3x the price!
https://www.cjponyparts.com/readylift-sst-lift-kit-2-1-2-f-150-raptor-2017-2018/p/692755/
ReadyLIFT 2-1/2" SST Lift Kit for all 2017-2018 F-150 Raptors.
Looking to upgrade your new 2017-2018 F-150 Raptor's suspension? ReadyLIFT has the answer if you're looking for perfect stance or more lift than the average 1-1/2" or 2-1/2" leveling kit can provide. This ReadyLIFT 69-2755 2-1/2" SST Lift Kit includes an OEM-style 4" cast iron rear block kit to replace the factory 2-3/4" block. This equates to 1-1/4" rear lift increase. In most cases this combination provides a visual level-but-lifted stance and the ability to install 35x12-1/2 tires on a 9 inch wheel with +12 offset and have no rubbing issues.
Manufactured with CNC machined billet 6061-T6 aerospace-grade aluminum construction, this SST Lift Kit is extremely durable and provides the safest means to lift and/or level your F-150 Raptor's front end. Retain suspension articulation while retaining the factory travel specifications with this ReadyLIFT 69-2755 2.5" SST Lift Kit. The kit is completed with a durable finish that matches the factory coilovers. The leveling kit has been specifically engineered to bolt right onto the factory Internal Bypass Coilovers. Factory wheel travel and droop length are maintained after completing the easy installation process.
Features and Benefits:
- CNC machined billet 6061-T6 aerospace-grade aluminum construction
- 10.9 grade mounting studs with nuts
- Durable finish matches factory coilovers
- Extremely safe way to lift your Raptor
- Maintains factory wheel travel and droop length
- Each kit includes new bump stops
- Keeps your factory ride
- Made In the U.S.A.
- Easy to install
T
Tlh235
Ok then...crossed off list! Haha. I’m easily influenced by emoji
DocSpooK
TechsAzz
- Easy to install
This will let me upgrade to 35” tires?!!
*********. Can’t even research their market.
Nick@Apollo-Optics
A 2 to 2.5" spring perch collar will level out your truck and allow you to run a more aggressive offset wheel without rubbing issues. And it'll be a bit cheaper while keeping the rear of the truck stock.
We offer an array of collars and would be happy to get you setup; let us know if we can help.
93,171
56,440
jumpcutter
