Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford Raptor Suspension Discussion and Modifications Forum [GEN 2]
Eibach Pro Lift Springs, Readylift rear Blocks, 37" tires on 2017 Raptor
This is a discussion on Eibach Pro Lift Springs, Readylift rear Blocks, 37" tires on 2017 Raptor within the Ford Raptor Suspension Discussion and Modifications Forum [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
Old 02-28-2018, 07:50 PM   #11 (permalink)
Originally Posted by jrobyutk View Post
Are you sure the Geisner is progressive? Everything I saw shows it to be a linear unless Iím mistaken. Iíll probably end up going with the Deaverís in the long haul in the rear knowing me but wanted to give this a shot first. What do you mean axle wrap is an issue with the OEM blocks? I would think that the ones that come in there Stock wouldnít be a detriment to the integrity of he truck, but Iím sure it wouldnít be the first time. Just wondering why they have them in from the manufacturer if itís bad for it
Axle wrap happens when you really get on it in 2WD. Twists your normally arched leaf springs into an S like shape. Then the rear end starts jumping. Can destroy your rear end and/or driveshaft. You're essentially giving the truck more leverage to twist the springs with your setup. Depending on how you drive it might not be an issue.
Geiser springs...
https://www.utvinc.com/ford-raptor/g...prings-2-lift/
My build thread: http://www.fordraptorforum.com/f65/w...6/#post1012544
Truckzor is offline   Reply With Quote
Old 02-28-2018, 08:37 PM   #12 (permalink)
Junior Member
I don’t know what the hell I was looking at then but you’re right they are progressive with Geiser.
ďNo tree, it is said, can grow to heaven unless its roots reach down to hell.Ē
jrobyutk is offline   Reply With Quote
Tags
37" tires, lift, readylift, springs, suspension
ReadyLIFT SST Lift Kit 2-1/2" F-150 Raptor 2017-2018 Tlh235 Ford Raptor Suspension Discussion and Modifications Forum [GEN 2] 7 02-28-2018 12:25 AM
So why did Ford use 2 inch lift blocks on the stock springs? Guy Ford Raptor Suspension Discussion and Modifications Forum [GEN 2] 21 11-08-2017 06:43 PM
Gen 2 Wheels Tires Eibach springs roostinyfz Garage Sale 3 11-04-2017 01:49 PM
Eibach lift springs ZaneMasterX Ford Raptor Suspension Discussion and Modifications Forum [GEN 2] 92 10-06-2017 05:21 PM
Readylift 1.5" Rear Blocks PacificWheel Garage Sale 5 05-19-2015 03:10 PM
