GEN 2 What code scanner should I buy?
mikepipe597
Tired of going to the local auto parts store for scanner. What scanner should I buy that will also allow me to erase all the codes once fixed? Reason I ask, recently had the P04DB (crankcase ventilation system disconnected) fixed the issue went back and erased the 2 of the three codes but the scanner wouldn't erase the code marked permanent.
PERMANENT
Permanent codes are a special
type of confirmed code that
only the vehicle can erase.
Has anyone experienced this?
Thanks
waddellw
Mississippi
Cheapest bet might be to get ford to erase it if you fixed the issue that caused it to appear.
danmcw34
Permanent code will erase itself after emission monitor self test has been performed and successfully completed and passed
Smokeshow60
SgtMajor of the MemeCorps
Southern Ohio
If you ever plan on tuning the truck in the future a ngauge tuner will do all that as well. If not forscan is the way to go
