Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford F-150 Raptor General Discussions [GEN 2]
Payload differences
This is a discussion on Payload differences within the Ford F-150 Raptor General Discussions [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
Reviewing the specifications for the 2018 Raptor I have a curious question about the payload and towing capabilities. The Super ...
Like Tree2Likes
  • 2 Post By kandewinn
Old 05-09-2018, 07:03 AM   #1 (permalink)
Swamp Fox's Avatar
Junior Member
Default Payload differences
Reviewing the specifications for the 2018 Raptor I have a curious question about the payload and towing capabilities. The Super Cab list having a payload capacity of 1000 lbs. and towing capability of 6,000 lbs. The Super Crew list it's payload and towing capacity at 1,200 lbs. and 8,000 lbs. respectively. The Super Cab weights 5,525 lbs. and the Super Crew weights 5,697 lbs. This makes the Super Cab 172 lbs. less than the Crew Cab (so I would assume its capacities would be that much greater) yet its towing capacity is 2,000 lbs. less and it's payload capacity is 200 lbs. less. Both the Super Cab and Crew Cab have the same engine and drive train (at least to my knowledge.) So the question is: Why does the Super Cab have lower payload and towing capabilities than the Crew Cab? My guess would be the Super Cab has different (softer) leaf springs than the Crew Cab for articulation.
There must be a good reason for the differences but doing a quick search on the internet does not show an answers to the question.
2014 Black Raptor Crew Cab. 2018 Silver Raptor Super Cab.
Swamp Fox is offline   Reply With Quote
Old 05-09-2018, 07:38 AM   #2 (permalink)
kandewinn's Avatar
Weight distribution. The longer the lever, the more force you can apply.
Robtor310 and Liv4Spd like this.
kandewinn is offline   Reply With Quote
Tags
payload, towing, weight
Payload Capacity and Maximum Recommended Long-Term Payload Karl_H Ford Raptor Suspension Discussion and Modifications Forum [GEN 2] 2 01-11-2017 12:26 PM
Model Differences funkcanna 2014 Ford SVT Raptor Forum (Reply Only) 10 06-24-2014 10:06 AM
Headlight Differences? alexlaughlin Ford Raptor Lighting Modifications Forum [GEN 1] 1 12-05-2013 04:14 PM
ok, so what are the differences? 87MJ Ford SVT Raptor General Discussions [GEN 1] 14 11-04-2012 06:55 PM
