POLL: help me decide my next tire size
What size tires should I get!?
  • Total voters
    27
prowakeskater
NorCal
Wheel is decided- 18x9 Fuel trophy in graphite, +1mm offset
I just cannot make a decision on what tire size I want to run with my mid perch!
My truck is unfortunately 99% street queen. I haven't jumped it yet and living in south florida, theres not a whole lot of areas to push its limits.
that being said, I'm OK with beating the pinch welds and trimming the stock fender as needed with the 37, IF its possible. Theres a guy running mid perch 37" with some trimming of the fender flare and fender on 0mm methods, but his tires are 37x12.5. I do NOT want aftermarket fenders at all.
so, here we go:
1) 37x13.5r18- Pictured here is a +0 offset, 17" toyo, which are 14.6" wide. This would be closest appearance to the cooper and toyo 18" which are both 14.2" wide. How did this guy make this work? idk but id love to find out. If it can be done, id prefer this route
2) 315x70r18- I like the 35.7" size, hate the puny 13" width. looks pretty nice with the +1mm offset pictured though
3) 325x64r18- 13.5" wide and beefy, but only 34.7" tall. May look a little off with +1 offset, pictured here is +25. To me, this size tire would be perfect with a lower offset wheel (+20 or so) and LOW perch. looks great but I would probably want to go back to low with this one..
so what do you guys think?
BearLeeAsian
Dallas Texas
Go 37"!! Toyo 13.5!
prowakeskater
prowakeskater
NorCal
They are, and those are also stock fenders on the top two photos of the raptor with 37" Toyos
BearLeeAsian
Dallas Texas
They look great. Rides great.
Butttt they rub at full crank .
Fiberwerx fenders came in today (thank you Travis)
Hoping to install those this Saturday along side with going to mid perch due to the 12+ on top perch issue.
prowakeskater
prowakeskater
NorCal
That's not a bad rub at all, but add 17mm and it my turn brutal
I'm thinking a little torching of the plastic to soften, then depressing with pressure for clearance would fix?
QTX
DFW
As the old diesel forums say....If you ain't rubbin, you ain't thuggin.
---------- Post added at 03:06 AM ---------- Previous post was at 03:05 AM ----------
Sharp Terrain. Can't wait to see with the fenders on. how much wider does it make the truck?
---------- Post added at 03:07 AM ---------- Previous post was at 03:06 AM ----------
Sharp Terrain though! How much wider to do the fiberwerx make the truck?
