Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford Raptor Engine Discussion and Performance Mods-6.2 Liter V8 [GEN 1]
6.2 swap
This is a discussion on 6.2 swap within the Ford Raptor Engine Discussion and Performance Mods-6.2 Liter V8 [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
What he said Sent from my iPad using Tapatalk...
Like Tree4Likes
Sponsored By: GotExhaust
Old 01-12-2016, 01:58 PM   #21 (permalink)
bstoner59's Avatar
does it come in shmedium?
bstoner59 is offline   Reply With Quote
Old 01-13-2016, 12:27 AM   #22 (permalink)
Junior Member
I know the 6.2 aren't the best engine out for modding but I wanna do something unique and stay away from the ls and coyote swap trend . Mmr make a forge block for the 6.2 for about 6k and hellion sells the turbo kit for 8k+ i know that it's not gonna be cheap but it's always something I wanted to do for my first truck, gotta keep it special.
---------- Post added at 05:27 AM ---------- Previous post was at 05:23 AM ----------
I would probably take it to a shop since I don't have the experience with swapping a different motor. I've seen that fox body with the 6.2 at the track he's running a manual transmission which is badass fast little car lol
73f250 is offline   Reply With Quote
Old 01-13-2016, 12:19 PM   #23 (permalink)
whoisbigman's Avatar
Do a 7.3 Powerstroke... fun and cheaper to mod for big HP... Go big or go home.
bstoner59 likes this.
2012 Tux Black, Loaded. Previous owner added Spray-in liner, bed cover, LED everything, AFE intake, Magnaflow Exhaust, mid-perch... other stuff I haven't found yet. Thank You whoever you are... I have added 37" Nitto tires, painted speaker grilles, Roush vacuum gauge for hubs.
whoisbigman is offline   Reply With Quote
Old 01-14-2016, 10:35 PM   #24 (permalink)
Wasn't aware of the MMR shortblock. Thanks for posting. I'll keep that in mind in case my factory shortblock grenades (as mentioned, my truck is currently getting a whipple, but I also went with 60 lb/hr fuel injectors, a monoblade TB, a 3.125" pulley, and a wide open exhaust system so there's a fair chance she'll blow up according to some people I've spoken to).
As for the Hellion, I looked far and wide for info on this kit but I couldn't find anyone who wanted to tune for it. None of the reputable shops I talked to wanted to touch it.
If money is no object, then by all means, go for it. I'm sure you can make it work.
As for me, I no longer have any interest in paying for people to learn on my truck.
Again, I recommend an LS or coyote swap. You'll get more power both more reliably and for less money.
Truckzor is offline   Reply With Quote
Old 01-14-2016, 10:54 PM   #25 (permalink)
mike.s's Avatar
Are you upgrading the oil pump gear?
I had the monoblade and it's a great TB, but it can be difficult to tune for. My RPMs would jump up and down a lot when stopping at a light. I ended up downsizing to the twin 68.
mike.s is offline   Reply With Quote
Old 01-14-2016, 11:05 PM   #26 (permalink)
I'm doing the billet oil pump gears, yes.
I'm also adding the CBR radiator to try to keep everything cool.
I have a lot of confidence in my tuner but if there are any issues I don't mind dropping down to a twin (though I may try the 71).
Lastly, even though I didn't want to rice up the interior, I ordered fuel pressure, air/fuel, and a bunch of other gauges (along with a dimmer switch so I could keep a low profile) so I could keep an eye on everything.
Worst case it blows up and I build a larger shortblock ;)
Old 01-14-2016, 11:18 PM   #27 (permalink)
mike.s's Avatar
You could also do meth injection. Helps with detonation. I wish I'd had more time to enjoy my 707hp meth injected Raptor. I also did an ATI super damper. Over 12lbs of boost lol.
Old 01-14-2016, 11:31 PM   #28 (permalink)
What did yours put down at the rear? How long did you have it? Any issues? Can you send me a link to the ATI damper?
I was just planning to run a bottle of octane boost at every fill up. Not really interested in another tank/lines to worry about.
Any other thoughts?
*edit* - I'm also still working on a dual catch can solution.
Old 01-15-2016, 12:13 AM   #29 (permalink)
mike.s's Avatar
Any other thoughts?
566 hp and 581 tq at the wheels.
ATI - Super DampersŪ for Ford Engines
I ordered the super damper directly from ATI over the phone. I got the 12% overdrive model which adds about 2 lbs of boost. With my 3.25" pulley my max boost was over 12. Besides adding boost, the super damper reduces the crankshaft vibrations which protects your engine.
I'm glad I had the meth at those boost levels. When I was at 9.5 lbs, my tuner saw knocking. With the meth kit, there was no knocking at 12.5 lbs. I had the pure meth kit from Alky Control.
Unfortunately, I can't really comment on reliability. I only had the meth kit and super damper for about a month before I turned my Raptor into a pancake.
Old 01-15-2016, 12:22 AM   #30 (permalink)
What happened?
Tags
raptor
8 Rib pulley swap One Slow 5.0 Ford Raptor Engine Discussion and Performance Mods-5.4 Liter Triton V8 [GEN 1] 3 05-20-2015 09:08 AM
5.0 swap ProjecT 9 Ford Raptor Problems and Questions Forum 4 01-26-2015 06:59 PM
Frame Swap abrown Ford SVT Raptor General Discussions [GEN 1] 20 02-03-2014 07:42 PM
Sony Nav swap zyvin Ford Raptor Audio/Video/Electronics Forum [GEN 1] 10 09-08-2013 02:37 PM
Anyone done a CAM swap yet? Mark Ducati Ford Raptor Engine Discussion and Performance Mods-6.2 Liter V8 [GEN 1] 2 06-14-2011 11:31 PM
