Introducing Stainless Works 3" dual-exhaust system for the Ford 5.0 F-150
Exhaust System
Improve the sound and performance of your Ford F-150 with Stainless Works' dual exhaust. With a one-of-a-kind sound, our dual muffler design and 3'' mandrel-bent (no kinks) tubing improves power output for high horsepower excitement. Choose our straight through S-Tube mufflers for aggressive acceleration with a nice growl at idle, or pick Chambered Turbos for a more mellow idle, that opens up to a muscle care sound when you hit the gas. Use our Performance Connect exhaust to fit to SW headers for true-dual torque and even more HP gains.
*Our exhausts easily install to a factory connection point or custom SW headers
*Our durable, polished tips made from 304L stainless steel
*Connect to factory Y-pipe or gain true-dual exhaust performance by connecting to SW headers
Performance Headers
Unmatched sound and performance: Gain power on-demand with our 1-7/8'' long tube header design for the 5.0L Ford F-150. Our USA made custom built headers improve your motors efficiency with huge gains in throttle response, torque and horsepower. The 3'' collector houses our integrated merge spike which promotes scavenging and a smooth balance in exhaust pulses. Choose between our high-flow 200-cell converters or the restriction-free performance of our converter delete (off-road) leads. Use our Performance Connect system, featuring our X-pipe within a resonator to connect with our True-Dual exhaust for additional torque and HP gains and amazing sound.
*Our headers are fully TIG-welded and feature 3/4-inch flanges for maximum durability, and provide a leak-free seal that will not warp
*Performance Connect headers include our 3'' X-pipe within a resonator which increases performance through scavenging and improves sound
*Choose between high-flow catalytic converters or our converter delete (off-road pipes)
