AJOmar
- Joined
- Mar 8, 2017
- Posts
- 7
- Reaction score
- 2
So I have been visiting this forum for quite some time now, found a lot of very useful information but never had anything to share. I have a 2014 Supercrew cab that is in stock condition, aside from 2 LED bars (22" under grill and 42" behind upper grill, both curved)
I have been planning my audio system for a while and finally worked out all the details (thanks to Birdman and Noah):
- Subs: 2X Skar 8" VVX-8v3
- Midrange: 2X Skar 8" PAX8
- Sub Amp: rockford fosgate prime R1200-1D
- Mids Amp: rockford fosgate prime R600X4 (bridging both channels for mids)
I will raise the backseats 1" by putting some steel block spacers on the stock seat bolts (it looks like I won't be able to lift the seat bottom fully this way). I will install all 4 speakers under the seat and front-firing in a custom box. Amps will go behind the rear seat back (heat issue???)
so my main question here is regarding tapping into wires with a LOC, since the signal reaches all OEM speakers and subs pre-amped and crossovered, that would mean the OEM sub wires are only good to power my subs, but not the mids, correct? if that was the case, then which speaker has the right signal (frequency) to tap into for my mids?
please feel free to comment/correct anything you see wrong with this build
