2010 Scab stereo upgrade.. Your expertise.
rkwjunior
Massachusettes
Hi all, i have a 2010 Scab with Nav and Sony system. As we all know the stock stereo blows, so i've done some research and put together this setup. Can someone tell me if this is GTG or do i need something else, or will it even work?
I'm going with the stock Nav/head unit
JL- Cleansweep
Infinity Kappa 5.25" components front with 5x7 speaker adapters
Infinity Kappa 5.25" non components rear with 5x7 speaker adapters
Powering those with a Fosgate 2400watt 4 channel amp from old truck
Sub is a Solobaric 10" L7. from old truck
Powered by a Fosgate Punch 500bd from old truck
Removing center channel speaker
Am i missing anything, will this be GTG, let me know what u think.
aka grumpy car stereo guy
where do you plan on putting that sub? it wont fit under a seat. and you should use 6 1/2" speakers, not 5 1/4" you will also need the summing device to go with the cleansweep
R
rkwjunior
Massachusettes
I'm fine with putting the small seat up and sitting the sub on the floor, i never usually have passengers, thats what i did in my old quad cab Hemi.
I didnt think 6.5's would fit. Do they make speaker adapters for the 5x7 to 6.5's??
Ok, the summing device it is.
Thanx
R
rkwjunior
Massachusettes
yes the bigger voice coil allows for more midbass and less distortion. also a wider variety of speakers can be used.
I'll check with the installer to see if they wil make them. If not, can you make up a couple pairs of speaker adapters and send em to me?
In your opinion, what am i looking at for cost to install everything.
---------- Post added at 06:03 PM ---------- Previous post was at 06:00 PM ----------
I must be really out of touch with the audio world, because i think the stock system sounds good
HAHA, you must be, it sounds terrible compared to what i had. My father thought it sounded great, i laughed.
It probably sounds good compared to some other oem systems.
come here so i can kick your ass......
i can make them, but the shop doing the work should be able to. its probably a 5-6 hour job for the complete install. the center console needs to come out to access the oem amp
