Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford Raptor Exterior Modifications Forum [GEN 1]
New Sliders with Hi-Lift points
This is a discussion on New Sliders with Hi-Lift points within the Ford Raptor Exterior Modifications Forum [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
I'm fixing to start a project on custom Sliders. They will have Hi-lift lifting points, 4 mounting locations welded to ...
Like Tree9Likes
Old 01-17-2013, 06:14 PM   #1 (permalink)
Dan06's Avatar
Default New Sliders with Hi-Lift points
I'm fixing to start a project on custom Sliders. They will have Hi-lift lifting points, 4 mounting locations welded to the frame, flat top with flare holes, and sprayed on bed liner.
They will probably be very similar to this
My question is would any of you be comfortable using an Hi-Lift on a Slider specially designed for it? I've heard a lot of negative discussion on them. Don't want to have the jack slip causing mayhem, possibly damaging my truck.
KaiserM715 likes this.
Dan06 is offline   Reply With Quote
Old 01-17-2013, 06:46 PM   #2 (permalink)
If its made for it,why not?
blood is offline   Reply With Quote
Old 01-17-2013, 06:50 PM   #3 (permalink)
Dan06's Avatar
Thanks. Kinda what I was thinking. However, after reading negative posts regarding them it was making me second guess it.
Old 01-17-2013, 06:54 PM   #4 (permalink)
BigJ's Avatar
No problem for me whatsoever. Got some made for that purpose actually myself: Sliders and Skid Plates, oh my! (WARNING: Pic Heavy!)
Consider making an adapter for your hi lift as well. A piece of 90deg angle iron large enough to cradle the tube... see what I'm sayin?
Icecobra likes this.
BigJ is offline   Reply With Quote
Old 01-17-2013, 07:02 PM   #5 (permalink)
Dan06's Avatar
I've actually looked at your thread many times. It was my original inspiration for my soon to be sliders. What size Hi-Lift are you using? I imagine due to our suspension travel it would require one of the longer models.
BigJ likes this.
Old 01-17-2013, 07:04 PM   #6 (permalink)
BigJ's Avatar
Yep I've got the Hi-Lift X-TREME 60". Have you seen how I mounted it? Works better than I could have hoped: HiLift Jack Mounted in the Bed - Tons 'o Pics!
Yukon Joe likes this.
Old 01-17-2013, 07:08 PM   #7 (permalink)
Dan06's Avatar
The mounting of the jack looks awesome. Have you used it much?
Old 01-17-2013, 07:41 PM   #8 (permalink)
Dan06's Avatar
If anyone had pictures of the Hi-Lift in use, I'd greatly appreciate it.
Old 01-17-2013, 07:44 PM   #9 (permalink)
BigJ's Avatar
Nope, not yet. Hope to never need to. The thing scares me a little, I aint gonna lie ;)
Old 01-17-2013, 08:09 PM   #10 (permalink)
Dan06's Avatar
I'm thinking when changing a tire, if I chain the axle up, the suspensions travel would be dramatically reduced. Read a WSI post somewhere regarding it. The chains used to turn the lift into a winch would probably work for this. I like the idea of having a backup winching device. Just seeing the Hi-Lift in action would make me feel better about my sliders design. I'm going with 4 legs, which may be unnecessary weight if I'm not lifting from them. Also, specifically leaving open areas in the flat top, so the Hi-Lift doesn't contact it. Once these are built I plan on using the lift until I'm comfortable enough to use it when it counts. Kinda edgy about messing something up though. That's why I was asking for in action photos.
Tags
custom, hi lift, jack, off road, sliders
Highlift Jack Points? RAPTILE Off-Roading Your Raptor 29 02-18-2015 02:35 PM
KHC Rock Sliders!!! khcdave Krazy House Customs 12 01-12-2013 06:58 AM
Jacking points for standard 2 ton floor jack Geno Ford SVT Raptor General Discussions [GEN 1] 2 01-06-2012 10:47 PM
tie-down points offroadshadow Ford SVT Raptor General Discussions [GEN 1] 8 01-27-2011 07:49 PM
