6.2 Y-Pipe help needed
Discussion in 'Ford Raptor Exhaust and Cutouts Discussion [GEN 1]' started by raptorpaul, Jan 11, 2018.
Sponsored By: Stainless Works
  1. raptorpaul
    raptorpaul Full Access Member
    34
    55
    22
    May 19, 2016
    California
    I took a large rock to the factory y pipe on the passenger side just behind the cat. There is a dent but no hole there, however it caused an exhaust leak at the manifold and y pipe flanged connector. I have tried to reposition it with no success and took it to a muffler shop who repositioned and put some sealant on the joint which worked for a couple months. The problem is back just wondering if anyone else has had similar issue or suggestions. I am tempted to cut the flange off and weld on a new one. Or if I buy a new y pipe no cat will it throw CEL? “Of course off road use only” and could I get it shipped to CA?
  2. jpwrx2002
    jpwrx2002 Full Access Member
    35
    67
    36
    May 1, 2017
    No cats will cause a CEL, it can be remedied with a tune but will show an O2 readiness fault at emissions time
  3. biturbomg
    biturbomg Full Access Member
    198
    28
    Jan 13, 2017
    If cheaper to fix do that if not just buy an after market y pipe with no cats and call it a day.
  4. Red01Z06
    Red01Z06 Member
    52
    6
    May 18, 2017
    San Antonio, TX
    I too had a leak and have been looking for after market Y-Pipes with cats for our trucks. I only see ones for long tubes. Are there any after market y-pipes that work with stock manifolds?
  5. raptorpaul
    34
    55
    22
    May 19, 2016
    California
    Only one I found was Bassani with no cats. Would have to swap out every two years. “When it drives on the street” for reg.
Share This Page
