Wondering which rigid light I have???
Mannyrz
Just me
Santa Clarita California
E4BE1C78-CCC7-4AF8-BE1E-97A32263BFCF.jpegJust picked these up used.. was wondering if anyone out there knows what model each light is, so I can get an idea what switch to wire them to.. and does anyone have an recommendations on where to get some harnesses for them… by the way there going on a 2020
Specialtyperformanceparts
thanks so much really appreciate it.. only one i was able to find was the sae after i typed in the numbers that were on the lens
Just a note. That is correct on the light patterns, but Rigid did do an UPDATE to their "Pro" series on those around 2016-2017? and they increased the lumen output by about 30%. Those are the previous gen versions. The new versions have SILVER print on the front of the case. The part numbers you have should be - 50481, 50231, and 20211. The new part numbers are all the same except they have a "3" at the end... So 504813, 502313, 202113.
You can Google those part numbers and "Rigid" if you want to check specs on your lights such as lumens or amp draw, etc.
John
