WOG Presents, RPG Offroad's RST18 and RST18 with Recovery Rack
Discussion in 'Westside Offroad Group' started by Brendo310, Jan 9, 2015.
  1. Brendo310
    Brendo310 Supporting Vendor Supporting Vendor
    293
    250
    Sep 20, 2013
    Los Angeles
    [​IMG]
    RST18: RPG RST18
    RST18 with Recovery Rack: RST18 with Recovery Rack
    Westside Offroad Group is proud to announce the Rear Shock Tower systems from RPG Offroad that pulls 18" of controlled wheel travel!
    The bed cage uses your choice of either 16" Fox 3.0 piggyback bypass shocks, 16” Fox 3.5” piggyback bypass shocks and pulls 18" of controlled wheel travel when combined with custom built National Leaf Springs and our custom extended shackles. Through our extensive torture testing, we’ve found this setup extremely reliable, smooth, and effective at conquering the roughest terrain, the largest whoops, and the biggest jumps that the Raptor can handle. The increased droop travel provided by a bed cage system makes terrain that would have been spine shattering in even a Stage 4 Raptor, cushion soft.
    RPG’s bed cage is the perfect solution for mounting your shocks and retaining as much usable bed space as possible. RPG Offroad engineering philosophy is to maximize both utility and performance, so the rack is low profile, both length and height wise, by design. Its low profile design ensures use of bed covers to protect your cargo. The design also minimizes the amount of cutting required to install the cage, minimizing the loss of usable bed cargo capacity.
    Huge gains in shock travel lead to increased speed and control and we think that leads to increased fun in the desert playgrounds. Minimal impact on your usable bed space and utility matches the Raptor’s concept of a desert monster you can use daily. Built using laser cut sheet metal, CNC bent, seamless tubing, precision welding in-house at RPG HQ for optimum fit and strength, and powdercoated black for protection against the elements. The RPG bed cage is your next step in unleashing your Raptor’s desert conquering prowess.
    This kit includes the rear shock tower; two weld on 4130 chromoly brackets for the lower shock mounts, and all necessary Grade 8 hardware.
    [​IMG]
    [​IMG]
    [​IMG]
    For those of you interested in adding functionality to the RST18, there's also the RST18 with Recovery Rack. Designed as a full bed system that gives you all the proven performance gains from the standard setup, and also adds on mounts for mounts for two 35” or 37” spare tires, a mounted floor jack and options for one 5 gallon jug with a Pelican case or 3 mounts for 5 gallon water or fuel jugs.
    [​IMG]
    Both kits are available for ordering now! Poke around on the website, figure out which kit you'd like, what shocks you want to run, and call me at 855-WOG-OFRD and I'll put together a deal for you on a kit that'll crush any factory replacement 3.0 Raptor!
    Gus00SVTL, LandFill, EFTOBIAS and 2 others like this.
  2. bstoner59
    bstoner59 does it come in shmedium? Supporting Member
    6,110
    4,756
    Jul 13, 2010
    Orange, CA
    Gimme dat
  3. Yukon Joe
    Yukon Joe FRF Addict
    42
    18,355
    11,596
    Nov 16, 2011
    Oak Island, NC
    Is there a template provided for cutting the bed?
    Thank You for your donations to Avery. We hit our goal!
    Yukon Joe
    Snoball 3
    Delta Lead
    www.runraptorrun.com
  4. NickPic83
    NickPic83 FRF Addict
    37
    9,641
    2,434
    Jan 31, 2012
    Rockland County NY
    That's pretty bad ass
    Brendo310 likes this.
  5. Brendo310
    293
    250
    Sep 20, 2013
    Los Angeles
    We recommend you have this kit installed at a shop but yes, we provide a template and instructions for installation.
    Any other questions please feel free to ask.
  6. Brendo310
    293
    250
    Sep 20, 2013
    Los Angeles
    The RST 18" has been updated to be even more BEAST MODE than before!
    We are proud to announce the RST 18" can now accept, Fox 3.0 16" Fox 3.5 16" and the all new Fox 4.0 16"
    With the addition of the all new Fox 4.0 bypass shock your options of terrain and possibilities have been expanded to a whole new realm!
    More details and pricing @ RPG RST18
  7. LONGISLANDRAPTOR
    LONGISLANDRAPTOR Full Access Member
    647
    283
    Jun 10, 2013
    Long Island, NY
    what would the travel numbers bet approx with Deaver springs?
  8. Westside Offroad Group
    Westside Offroad Group Supporting Vendor Supporting Vendor
    2,589
    2,214
    Apr 8, 2012
    Westside
    With deavers and the RST kit you will get 18" of controlled wheel travel. Give us a call or shoot me a PM for more info
  9. bigjerry
    bigjerry Member
    5
    May 30, 2013
    If I already have your standard duty stage 3 rear would I have to buy new leafs? Also does this still work with your air bump and frame brace?
    byz250f likes this.
  10. byz250f
    byz250f Full Access Member
    338
    136
    Mar 2, 2017
    I would like to know this also.
Share This Page
