GEN 2 Wiring question-Adding powered sub to non B&O system
sajprice86
Richmond VA
Hello all,
Just picked up a GEN 2 Raptor without the B&O system. So far I've upgraded the front and rear door speakers with JL Audio but it really needs a sub. Im looking to purchase a powered sub but am not too sure where to wire the remote and inputs to the factory unit. If it were an aftermarket head unit it would have the RCA jacks and a remote wire but I would imagine the OE unit does not. Any help would be appreciated!
Drgonzo3000
North Carolina
Use the Front speakers for signal. The rears I think are crossed something like 180hz, Fronts are probably at like 100hz. I have the add-on kicker 8" sub that came with the truck when I bought it. It sounds like crap so I originally tried to tap into that sub signal which caused a bad ground loop and introduced tons of noise into the system. So I pulled that out and tapped into the speakers for the PAC signals. I originally tried to use the rears and it sounded like mud. Tapped into the fronts and it was better but still nothing like the the bass I had in my 2015 with sync2. Plus the stock unit tapers off lows the higher the volume goes. Overall pretty shity for trying to add a simple sub into the system.
AnacortesTom
Anacortes wa
Go nav tv. Had a pro set up my 2 12s in the JL audio stealth box and had some sort of JL box that gave a input for my amp but nothing sounded right till the nav tv unit was installed
sajprice86
sajprice86
Richmond VA
Do you remember which color's the wires were for the fronts in the harness?
AnacortesTom
Anacortes wa
The installer, before the nav tv was installed, removed the stock sub and used its input for the amp. The subs output turned down in volume as the head unit turned up. I heard this can be defeated I heard through forscan
The Car Stereo Company
aka grumpy car stereo guy
here, on frf
i have a wiring guide posted in this section somewhere. it will have the wiring colors for the sound system. definitely do not recommend getting the signal from the oem sub.
as far as the nav tv, that is the best option to use when integrating the 18+ sound system. and is the only option i use when doing complete upgrades. if you are only planning on adding bass, and not upgrading the rest of the system, i would look into amplifiers that take a hi level input, or use something like the audiocontrol lc2i, or the audio mobile lds. definitely not the best, but is a budget friendly option to add a sub and get bass. not the cleanest sound, but will be better than whats currently in your truck.
AnacortesTom
Anacortes wa
The lc2i is what we used before the nav tv unit and I didn’t like it at all. Liked to have heard it without using the stock subs channel for sound. Either way it sounded great when done right.
Drgonzo3000
North Carolina
