Help SupportFord Raptor Forum by donating:
Help support Ford Raptor Forum :
Winter Driving in 4WD High
Discussion in 'Ford SVT Raptor General Discussions [GEN 1]' started by marioec, Dec 22, 2014.
  1. marioec
    marioec Full Access Member
    102
    21
    Nov 29, 2013
    South Florida
    So, all 4WD trucks and SUVs that don't have AWD state that you should not drive on dry pavement in 4WD High.
    But, when driving in snowy conditions, especially in the mountains, sometimes the roads are blowing snow, ice, but mainly flat. It is exactly at these times when you need the 4WD most, however, i get mixed signals on exactly when you can use it. It almost sounds like 4WD high is not really helpful for highway snow driving. since i'll be driving from Miami, FL in to Bonne, NC mountains this coming weekend and then going up US-74 W to Ellijay, GA i would like to put it in 4WD and drive over 45- 65 MPH on icy roads if there is any, but not always fully covered with snow...like patches of snow, clear, ice, patches, ice, etc.
    Any insight on the correct use of 4WD high would be useful, but i have read the manual and it says not to do that.
    Thanks for the input.
  2. lka
    lka Full Access Member
    38
    470
    166
    Nov 22, 2014
    Left Coast
    If it's snowing or icy I drive in 4H always have my whole driving life, I've always owned 4x4s and I've never had one break I've conservatively owned 20 different 4/4 vehicles. But I'm only 34 so maybe someone with more experience will differ but I always have and always will, that's the main reason for me to buy 4/4s oh and I average 100m a day have since around 21. My raptor isn't a month old yet and I'm about to hit 3k and in every snow and most days after the storms I've driven the raptor all day in 4/4, I want to be able to jump out of the little cars way when they come spinning towards me lol. It's all work miles. Well mostly lol.
    Java likes this.
  3. SilentShooter
    SilentShooter FRF Addict
    3,055
    1,963
    Dec 29, 2013
    Siesta Key, FL
    You can run 4hi any time you want. You should only lock the rear when you are on soft surfaces.
    They say not to run 4hi due to wear on tires and such but will not harm the truck
  4. Ramrodthrusterpuppy
    Ramrodthrusterpuppy Full Access Member
    215
    78
    Jan 18, 2012
    Ottawuh, Canaduh!
    Mmmm....not quite. You don't want to be in 4WD (high or low range) on dry pavement (for example) because when you turn, the front wheels will be turning at different speeds (outside wheel will be turning faster than inside wheel as it's covering a longer arc). Therefore, usually the inside wheel needs slippage in order to equalize the speed otherwise differential gears will explode.
    So as long as you have a somewhat slippery surface where the wheels can break traction to equalize speeds, you won't do any damage.
    Personally, I usually always use 4WD high range on snowy roads.
    Idleone, Taxman, Hoverp and 2 others like this.
  5. Huck
    Huck FRF Addict
    4,134
    1,802
    Aug 26, 2012
    Chicago Sw Burbs
    Wrong,
    The raptor has open diffs. No matter if you are in 4wd hi or 2 wheel all wheels will rotate at any speed they want.
    Only thing that locks in the raptor is the rear diff. You can drive in 4hi all day everyday and other than normal wear and tear from being in 4hi and a loss of mpg your perfectly fine.
  6. Bulletnjm
    Bulletnjm FRF Addict
    6,396
    3,787
    Mar 31, 2014
    New Jersey
    What about the torsen on the 12+?
  7. hagak
    hagak Full Access Member
    120
    29
    Nov 30, 2014
    Also the transfer case provides no differential between front and rear, you will get binding even with front and rear open diffs
    Tituslloydpullo likes this.
  8. SilentShooter
    3,055
    1,963
    Dec 29, 2013
    Siesta Key, FL
    The torsen is not a full lock, so should not cause an issue.
  9. Aramco Raptor
    Aramco Raptor Full Access Member
    498
    709
    Dec 8, 2014
    Montreal, Canada
    Personally I only use 4 high if the road / highway is snow covered (in my previous vehicles) as I have yet to drive my Raptor.
    I will likely continue to do so.
    I have never broken anything but also don't like the sound/feeling when in 4 high and turning on dry pavement.
    Just feels wrong.
    Taxman, beachz and BAJASVT like this.
  10. gwpfan
    gwpfan Full Access Member
    444
    126
    Mar 25, 2014
    While the torsen may not provide a full lock, it'll definitely cause the front tires to 'skip' while on dry pavement. I was driving on pretty muddy roads and forgot to turn the 4 Hi off once I hit pavement and was making a really sharp left since the roads weren't perpendicular and the 'skip' made me realize I was still in 4WD. Didn't hurt the truck as far as I could tell, but I am sure overtime between tire wear and such something would give.
    The biggest thing is just keep in mind while in 4WD is turns, especially sharper turns and even that much more so when you lock the rear diff....
Share This Page
