Windshield washer problem
Ryguy84
North Bay, Northern Ca
My windshield washers arent working. I checked the lines everything looks good no pinches. I dont hear the motor turning on when I push in the button. I hear the motor turn on for the front camera washer and it sprays the camera with fluid. Is there a fuse or relay that works for the windshield?
Raptor911
Ashburn, VA
Dumb question. How are you activating your windshield wipers? The windshield wipers and front camera do not share the same button.
R
Ryguy84
On the stock Im pushing the button in for the winshield the wipers move nothing sprays and I dont hear the motor turn on. For the front camera I twist the stock where it shows the camera and the motor turns on it sprays.
Raptor911
Ashburn, VA
OK ... just making sure.
next step is to check the fuse. Check your owners manual.
c130ldmstr
Little Rock, Arkansas
Hey I'm having the same issue. Did you get the problem resolved? Mine at the dearlership now. They've replaced the switch on the turn signal arm and that didn't fix it. Now they're waiting on new pump!
Jigks
Perth, Australia
I have the opposite problem, my front camera washer doesn't work. The motor which is the same unit, works for the windscreen but not the camera. Considering only two wires go to this pump, I am trying to figure out how it send fluid through the other hose?
---------- Post added at 11:15 PM ---------- Previous post was at 11:14 PM ----------
Oh and does the camera have to be on for the washer to work?
