Window motor replacement
coachhomer
Anyone replaced the motor for the window? Mine has apparently gone bad.
Thanks!
C
MTF
Celebration, Florida
It's probably too late for you if it's clicking easily right away.
Never use WD 40!!! It's the worst product on the planet for lubing anything!
It's a penetrator/cleaner and will destroy anything that needs a coating of lube.
I spray the cables once a year a couple of times making sure it gets all in the cable guides
and clean and spray ( a little and wipe ) the top and bottom rails so it can slide easy.
I love this stuff, I spray my rear springs with it also!!!
