Winch deals just for you!
RSiWORKS
S.C.S. Michigan
Contact me for the best available pricing on Smitty Bilt or Warn Whiches.
Some nice Winches for you to look at.
9.5XP-S Self-Recovery Winch
Part Number: WAR87310
Rated Line Pull: = 9500 lbs.
Voltage: = 12V
Motor: = 6.0 HP
Remote Control: = Remote switch, 12 ft. lead
Gear Ratio: = 156.1
Size: = 22.7 in. x 6.3 in. x 7.7 in.
Weight: = 87 lbs.
Synthetic Rope = 100 ft. of 3/8 in.
Fairlead = Hawse
Reg. Price: $1,549.00
PM me for the best available pricing.
X2O Comp Series, 10,000 lb. Amphibious Winch
Part Number: S/B98310
Rated Line Pull: 10000 Lbs single-line
Gear Train: 3-Stage Planetary
Clutch: Rotating Ring Gear
Drum Size: Diameter 2.5 (63.5mm), Length 8.75 (222mm)
Battery Leads: 25mm
Mounting bolt pattern: 10 x 4.50
Motor: 5.5hp Series Wound
Control: Remote Switch, 12' (3.7m) lead
Gear Ratio: 218:1
Brake: Automatic In-The-Drum
Synthetic Rope:94'of 5/16"
Finish: Black
Weight:88 lbs
Reg. Price: $849.99
PM me for the best available price.
Please contact me for the best pricing on a specific Winch.
R
RSiWORKS
S.C.S. Michigan
VR12000 Winch
Part Number: WAR86260
Rated Line Pull: = 12000 lbs.
Voltage: = 12V DC Series Wound
Geartrain:= 3-stage Planetary
Gear Ratio: = 216:1Size: = 21.83 in. x 6.3 in. x 6.97 in
Weight: = 89 lbs.
Wire Rope = 94 ft. of 3/8
Fairlead = Roller
Type of Winch: = Electric
Reg. Price: $679.99
Would anyone be interested in a group buy on one of these Winches?
---------- Post added at 10:51 AM ---------- Previous post was at 10:40 AM ----------
HitchLink
Part Number: F5500020-01
- Precision CNC machined 6000 series aluminum
- Weighs only 1/3 of conventional steel designs
- Rated at 9500 pounds
- Ultimate failure at 51,000 pounds
- Fits standard 2 inch receivers
- Fits standard 3/4 inch screw pin shackles
- Anodized and powder coated for oxidation protection
Price: $74.95
Colors still available: 3-RED, 1-BLUE, 3-BLACK, 1-SILVER
These things are going fast.
---------- Post added at 11:05 AM ---------- Previous post was at 10:51 AM ----------
images.ashx
ProLink
images.ashx
Part Number: F5500010-01
- Stainless steel pin
- Fits all steel cables and synthetic ropes up to 3/8" in diameter
- Screw pin shackles are up to 5X stronger than conventional winch hooks
- Recover straps cannot slip out of a shackle like they can with hooks
- Billet construction - precision machined from 6061-T6 Kaiser Aluminum round bar
- Can be installed and removed in minutes - simple snap ring removal
- Cinches neatly against all types of fairleads - Hawse or Roller
- Beautifully anodized and zinc plated in the USA
Price: $124.95
Colors still available: 3-RED, 1-BLUE, 4-BLACK, 4-SLIVER,
ProLink Loaded
images.ashx
Includes Titanium pin and rubber guard.
Price: $149.95
Colors still available: 19-RED, 5-BLUE
R
RSiWORKS
S.C.S. Michigan
ZEON 10-S Recovery Winch with Spydura Synthetic Rope
images.ashx
Part Number: WAR89611
Rated Line Pull: = 10000 lbs.
Motor: = 12V
Gear Ratio: = 216:1
Size: = 24.25 in. x 7.15 in. x 10.52 in.
Weight: = 75 lbs.
Synthetic Rope: = 100 ft. of 3/8 Spydura rope
Fairlead: = Hawse
The next generation of winches is here: WARN ZEON. With a modern rugged design, upgraded internal components, and increased performance and durability, ZEON is a new name from the most trusted name in winches. With a bold look and power to match, the ZEON is like nothing you’ve ever seen before. Unique exterior styling and symmetrical design give this winch a look that is advanced, capable, and strong. New-design planetary gear train and series-wound motor deliver fast, quiet, and reliable pulling power. Satin-black powder-coated finish with stainless steel fasteners and clutch lever looks great and inhibits corrosion. Convertible control pack can be attached to the winch or remotely mounted, allowing for various winch mounting options and looks (Relocation kit required and sold separately). Large diameter, aluminum winch drum reduces rope wear, is light weight, and has an integrated rope anchor for easy rope installation. IP68 rated for improved winch sealing to keep the elements out. Backed by the WARN Limited Lifetime Warranty.
Retail Price: $1,149.00 /plus shipping
Contact me for your FRF Discount.
Goose64
Chicago
Warn powerplant dual force hd
Hi will the WARN POWERPLANT DUAL FORCE HD, fit on my raptor ? looking to use it with the Ford Hidden Winch Mounting Plate,
Thanks
R
RSiWORKS
S.C.S. Michigan
Thanks
I'm assuming it's going behind your stock bumper?
It may be a very tight fit by the looks of it but I'm not 100 percent sure on that and if I were to guess I'd say no.
Size: = 24.31 in. x 6.8 in. x 13.75 in.
I personally have not seen one of these in person and it looks to be a great package for sure to have a winch and compressor in one.
Yukon Joe
Russellville, AR
Thanks
Try it and let us know. This would be my next winch for sure. I've installed both a winch and onboard air. Both were a PITA to complete. So if you can do it all in one shot, I say go for it.
Yukon Joe
www.RUNRAPTORRUN.com
