chance3322
So best way to level the truck is mid perch? Which i plan on doing before i get my tires........
Want toyo 35 M/T's, With method's
Whats the off set all about?
With the 0 degree offset they stick out of the wheel well about another inch or so. As long as you aren't running PDP mudflaps upfront you will not have a rubbing issue even on low perch. 35" fit perfect. In fact your stock BFG's are 34.6" I believe. The stance with Method rims is the best look of all the offsets out there, but then again that is just an opinion.
