Will Motorcraft 200amp HD alternator work?
radelow
Need to replace alternator. Does anyone know if the HD factory alternator will work? Model GL-8656. Can’t seem to get definitive info on it. Would like to stick with factory parts...
Mark
dhanni848
Nashville, TN
I would like to know the answer to this as well! I just replaced mine yesterday with (sorry to say) an O'Reilly remanufactured one, still had battery light so took it back, tested and said voltage regulator was bad, replaced making them test new one before I left, said was good, install, and still light on. Drove to Advance and tested said everything was great. Load output was 13.5 volts. Battery is charging and holding good too. Losing my mind!
If I need to get a Motorcraft 200 I will, but would love to hear what others have done and if you figured yours out.
R
radelow
Working great! Seems to have no problems and bolted right up.
dhanni848
Nashville, TN
Thanks for the feedback. I think I may have some other issues going on. No battery light for a while and then back on again, but everything at battery and alternator look good. Only does it when I get up to speed and it runs fine! Always something
