Why did Ford drop PSI from 44 to 38 for Gen 2?
vegascarnut
Henderson, NV
Door sticker on Gen 2s is 38 psi, but Gen 1s is 44 psi. The weight difference is only 500lbs total.
Does anyone know why? I'm thinking of dropping my street pressures from the 44 for less bounce in the rear. Maybe drop to 40 at least, but still wondering why the big drop from Ford.
Thanks!
Sernas
Gen 1 trucks came with D load range tires and gen 2s come with C load range. I’m not sure if that has anything to do with it. I run KO2s C load range with 36 psi front 34 in the rear. The ride is a lot smoother with that air pressure. Most people lower their air pressure for a better ride give it a try.
vegascarnut
vegascarnut
Henderson, NV
I'm going to try it. Tires really ride great overall, but always trying to make things just a little better! Haha. I'll take it down to 38 and see how that feels first. I run load range E tires because I tow a boat quite a bit. 44 PSI seems like overkill for unloaded daily driving though. Thanks
Pacific Wheel
Reno, NV
If you can run closer to the 35psi range on the GEN1 it does kill a lot of the bounce. The 36/34 combo mentioned above is pretty much spot on for comfort IMO. If you don't re-program the tpms threshold you might get a tpms light with the GEN1. I think it kicks on at 38 or 37psi
vegascarnut
vegascarnut
Henderson, NV
Thanks Justin. I have a programmer so I can adjust TPMS. I'll give it a shot today, and see how it feels.
500mag
Georgia
That is the reason. However, I still run 38 psi with my D-rated 37s.
vegascarnut
vegascarnut
Henderson, NV
Do the higher load tires D/E require higher pressures, or is it just that they can handle them with the extra load? I still want to drop pressures to 35-ish if I can for around town driving.
500mag
Georgia
For the higher loads. If you are not towing/hauling heavy, 35 should be fine.
vegascarnut
vegascarnut
Henderson, NV
I pull a double axle boat trailer. It's about 5,500 lbs of boat/trailer a few times each summer. I forget the tongue weight, but it's around 500. Hasn't ever "felt" heavy behind the truck, and does have surge brakes.
