Why are chase lights so important while off-roading?
Baja Designs
At Baja Designs our products are not only for performance, but also safety. While an effective forward-projecting lighting package is so you can see where you're going, chase lights allow others to see you. Adding a chase light allows for visibility in the rear when encountering dust or harsh conditions so your vehicle can be easily seen by groups behind you. The chase light often gets overlooked as the last piece to the puzzle for most lighting packages, however, a chase light should be one of the first light modifications you should consider when building an effective lighting package for your offroad vehicle.
What’s the best color for a chase light?
For optimal performance in dust, snow, or fog, amber is the ideal choice. While red, green, or blue lenses can be used, they are generally used for race applications only. Amber light is universally recognized as a caution light, making it a great option for chase lighting as well. Additionally, amber effectively cuts through dust and inclement weather, improving visibility in challenging conditions.
What is the ideal lens when running an Aux light?
The two best lens choices are Wide Cornering or Work/Scene. By flooding the light, you create a more enjoyable experience for those behind you. It's essential to diffuse the light as much as possible to prevent blinding others, while still making it easy for them to spot your position on the trail.
With Baja Designs UService Technology, your chase light doesn't have to stay a chase light forever. You can easily swap the lens pattern or color, with the exception of the RTL, allowing you to reposition the light anywhere on your vehicle without needing to purchase a new one. Plus, if you already have a forward-facing Baja Designs light, you can simply buy the appropriate lens and convert it into a chase light.
Baja Designs Solutions
RTL- Rear Tail Light
RTL Clear: Solid Red, Solid Amber, White Center Light, Solid Amber, Solid Red
RTL-B: Solid Red, Solid Amber, Blue Center Light, Flashing Amber, Solid Red (Race Series Specific)
RTL-G: Solid Red, Solid Amber, Green Center Light, Flashing Amber, Solid Red (Race Series Specific)
RTL-W: Solid Red, Solid Amber, White Center Light, Flashing Amber, Solid Red
RTL-S: Solid Red, Flashing Amber, White Center Light, Flashing Amber, Solid Red (amber sections offer individual controls or can be configured to function as turn signals.
Squadron
Squadron Sport W/C Baja Amber
Squadron Pro W/C Baja Amber
S2
S2 Sport W/C Baja Amber
S2 Pro W/C Baja Amber
S1
S1 Baja Amber
S1 Universal Hitch Light Kit
So, which one is right for you? If you're looking for a simple, compact setup, the S1/S2 provides an extra layer of safety without breaking the bank. The Squadron light, though slightly more expensive, offers great versatility in various applications and mounting positions. Its increased intensity and power enable it to serve as a chase, cargo, and scene light all in one. The RTL is our premium option, offering additional features like brake, reverse, and chase functions, unlike the basic on/off function of traditional auxiliary lights. No matter which setup you choose, one thing is certain: safety comes first when off-roading, and regardless of your budget, we have a
trusted solution for you.​
Brahian Herrera | Forum Sales & Support
Email: [email protected] | Phone: (760) 560-2252 Ext 201
Roush2568
Well-Known Member
Colorado
I throughly enjoy turning my bright white rigid chase lights on when the tailgaters get to close for my comfort. It greatly improves my night time visibility to see exactly how close they are to my rear axle.
Jokes aside, great information in OPs post.
criminal
I agree and admit I am in this situation. Any good resources to look at for install instructions? Chase and 3rd brake lights seem a bit more involved from what I have heard but have not researched much.
HORN HIGH ACES
Colorado
Nex
RIP CoronaRaptor
Washington State
Another easy mounting solution. I had installed some nutcerts on the bed. Then ran the wire between the bed and cab to the frame, then up to the uplifter wires. I later moved onto a GJ 3rd brake light.
