Help SupportFord Raptor Forum by donating:
Help support Ford Raptor Forum :
GEN 1 Whipple Kit Install :D
Discussion in 'Ford Raptor Engine Discussion and Performance Mods' started by Dalamar, Dec 30, 2018.
Sponsored By: GotExhaust
  1. Dalamar
    Dalamar Full Access Member
    44
    107
    77
    Oct 15, 2012
    SLC, UT
    Hi guys,
    Happy holidays.
    I wanted to post up this thread to share the fun, and am very open to feedback from others that have supercharged their Trucks.
    Started the install today.
    Here's some pics:
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  2. Dalamar
    44
    107
    77
    Oct 15, 2012
    SLC, UT
    [​IMG]
    [​IMG]
    I believe Whipple uses the GT500 TB?
    [​IMG]
    [​IMG]
    This is how far we got today.
    Drain Radiator, remove bat and air box, Trans crossmember ect.
    These are going in on Monday:
    [​IMG]
    Shipped the PCM to Whipple today...
    Will update you guys more as we get it Done.
  3. 1BAD454SS
    1BAD454SS Full Access Member
    188
    109
    Aug 13, 2017
    Use real sticky grease to hold the o rings up on bottom of intake that go to each cylinder ,so they don't fall out when you are trying to set the intake manifold on.
    I have larger heat exchanger like you have, but will be going back to smaller exchanger with my own fans at end of this month you won't have issues where you live, but in summer here in arizona i have hi coolant temp issues only at 80mph+ and 90+ degree air temp , Because it blocks so much airflow to radiator. I also just got my Ron Davis Radiator revamping my entire cooling system , new hoses ,thermostat, intercooler pump. I have one of the first few whipple kits released back in 2012 for 6.2 motor. 50,000 miles so far on whipple kit , no issues .
    Also another consideration Your alternator will now be under the supercharger ,Going to be a pain to remove super charger if it goes out , not sure how many miles on your truck , i installed a new DC power 275 amp at same time as supercharger install.
  4. Gary E
    Gary E Full Access Member
    67
    279
    134
    Jun 11, 2017
    Medford, Oregon
    Where did all that debris in the valley come from? Looks like tree needles and such.
    What brand of headers?
    Going with true dual exhaust?
  5. Dalamar
    44
    107
    77
    Oct 15, 2012
    SLC, UT
    Thanks man,
    I'm glad you mentioned cooling, I was looking at the stock Rad which is only about 1" thick and wondered about the heat discipation with the added heat of a blower. on my mustang I had to swap the rad after adding a turbo. Where did you get your Radiator? I did some searching, not much for Gen1 6.2.... Thanks for the feedback :waytogo:
  6. Dalamar
    44
    107
    77
    Oct 15, 2012
    SLC, UT
    I believe they're American Racing, will double check the box on Monday. My tuner had them on the shelf.
    I kind of like the side exit, dual slashed tip. not sure on rear exit yet.
    On the debris, I think at some point my truck may have eaten a pine tree! :)
  7. Gary E
    67
    279
    134
    Jun 11, 2017
    Medford, Oregon
    I utilized the true dual Stainless Works Lightning style side exit. It got rid of all of that over the axle piping.
  8. 1BAD454SS
    188
    109
    Aug 13, 2017
    IMG_20170227_181902.jpg Ron Davis Racing Radiators , Glendale Arizona. Looks like a piece of art work, cant wait to get it installed very nice welding , he builds them per order, takes about a week to build if he doesn't have one on shelf. Direct fit no modifying anything. Its pricey comparing it to CBR or mishimoto a lot better quality . http://www.rondavisradiators.com/Ford-Raptor-Radiator.htm
    My high temp are due air flow , ADD bumper and lights i have dont help either
  9. EricM
    EricM FRF Addict
    1,341
    806
    May 11, 2016
    Cincinnati, OH
    It's not sealed off by the stock manifold.
    Anthony k likes this.
  10. MTF
    MTF FRF Addict
    3,491
    877
    Nov 27, 2010
    NYC
    The larger heat exchanger with fans is necessary! Larger CBR radiator is a bonus!!!
    Make sure you have the tuner adjust the OEM radiator fans to jump on sooner (175 degree) and at 100%
    Stock setup is set to jump on at 207-212 which is way too late and hot for what we need.
    The problem is if the radiator fans are not adjusted to keep the engine cooler it doesn't matter what you do to improve air flow.
    If the fans aren't running, not enough air will get through the radiator!
    I also see high flow cats, are they Green cats?
    If not your going to need rear O2 spacers if you need to pass state inspection.
Share This Page
