GEN 1 Whipple Coolant Issues
basile
Georgia
Hey, ya'll I have 2014 with a Whipple on it and I've been having some major coolant problems lately. Just check my coolant take for the supercharger's intercooler the other day and realized it was empty. I filled it up and started my truck and every last bit of the coolant shot through the exhaust. Any idea what this issue could be? Could it be that the supercharger IC or gaskets are gone? I have no idea how long my supercharger has been running without coolant. It has sounded normal for the most part prior to this issue, thanks in advance.
MTF
Celebration, Florida
Someone else just recently had a HE to IC coolant problem, turns out the IC had a crack and purchased a new one for $900
Hopefully yours is just that and not more involved.
And if it's just a crack and you have a chop that has a good TIG welder for aluminum, you save some $$$
B
basile
Georgia
Hey, man thanks for the reply. Im, not the most mechanically inclined and I'm having a shop handle it. They seem to think it's the gaskets but from what I've read it's the IC. When I say all of the coolant shot through the exhaust I mean it lol. Hopefully, they just have to pull the sc and put in a new IC.
Dane
Littleton, CO
Maybe I'm missing something, but doesn't this mean the coolant is entering with the air and through the cylinders? Does this terrify everyone else as much as it does me?
B
basile
Georgia
Yeah I've got no idea. was up at the shop noticed there was no coolant. Filled it up and fired the truck up, all the coolant shot out. Does this sound like the IC or possibly another issue? Terrifying...
Dane
Littleton, CO
Sounds like IC to me, that's where the coolant could transfer into the air flow. Crack? Gasket? I don't know how you would know until you got in there.
To be clear, IC, not heat exchanger. Folks frequently mix them up.
B
basile
Georgia
Yeah really hoping nothing else is damaged also hoping the Whipple isn't trashed from running it with no coolant for god knows how long.
MTF
Nothing would happen to the Whipple unit from running hot or getting wet, people run water/methanol through it.
But I would drain and replace the gear oil even though it's good for a 100,000 miles., since it will be off anyway.
Luckily you didn't hydro lock a cylinder, that would have been a big mess.
I guess the properties in the coolant prevented that from happening.
BTW, there isn't any gasket, the IC is a self contain unit with a inlet and out threaded nipple connection.
Taking the IC out of the intake manifold can be a pain.
And you'll probably need the O-ring/gasket set to put it all back together.
B
basile
Georgia
But I would drain and replace the gear oil even though it's good 100,000 miles., since it will be off anyway.
I really appreciate it, man. Sending this to the guys working on it now. They basically gave me the same rundown today. They said they got all the coolant out of the cylinders and they're taking the sc off tomorrow to have the IC repaired and they're ordering a gasket set.
HighHP
E WA, N ID
I have a Whipple SC with probably the same I/C as well. Please keep us posted on the problem and the fix.
