Which Wheel Setup?
fkim119
Irvine
Hi All!
I finally have my BFG Blue dots come in.
Currently running 37x12.5 R17 Toyo RT Trails on my Vorsteiner Victory 6 in brushed liquid smoke with code orange outer ring.
I think there is too much color going on their once I put the BFG Blue's on. Thinking about switching it over to my custom Titan 7 in grey diamond finish with brushed lips. Also super light ( 20lbs per corner ) since the BFG's are about 80lbs per corner.
Kids love the colored ring. Daddy likes the simpler look of the Titan 7's.
Which would you chose? Pics are AI generated.
Titan 7's
Vorsteiner
RoNiN Raptor
Army Supporting Member
Arizona
Either one looks good, but I prefer the titans. Seems a little more subtle, less busy looking.
The blue dots look mean!!! Curious how well they will hold up.
F
fkim119
Irvine
I feel like you're about to have a full garage and I'd hate for these to get dusty just sitting there... how much would you want for this set up(wheels only)
I feel like I would lose too much money on them. The rims by itself in this finish is about $6K new. Shoot me an offer, maybe it will get me to sell. They are light compared to most cast options.
tlrskunk
Coweta, OK
Oof. That's more than I'm willing to even offer for truck wheels. Even if I love the look.
thanks for the info.
Fulshear, TX
I'm a fan of simpler the better, hence my name on here. But there is something about the colored ring and graphics that really pops and is unique. However, if you were to remove the graphics, the Titans would look CLEAN. Both look solid, though.
F
fkim119
Irvine
Thank you all for the input.
I have about 200 miles on the "blue dots" and have some feedback on the tires compared to my 37x 12.5 R 17 Toyo RT Trails and the OEM BFG's.
I have driven 26K miles on the RT Trails on my 25' R and owned a 24' 37PP Gen 3 with 20k on the OEM BFG's.
PRO's of the "Blue Dots"-
  1. The ride is back to OEM BFG levels compared to my load E range RT's
  2. These tires are bigger then a 37" tire by .25".
  3. Very low tire noise at hwy speeds (really surpising). Quieter then the RT's by a lot. The tires are even quiet with the windows down. You can hear my Raptor just by the tires coming from down the street for the RT Trails.
  4. It looks amazing mounted up
  5. BFG's are notorious for difficult balancing but these tires balanced really easily. No problems at all.
  6. I can run a higher pressures on the "Blue Dots" and it still rides better then the RT Trails. Hoping this helps a little bit with rolling resistance. Ran 34 psi on the RT Trails to gain some suppleness. Running 38 on the BFG now.
  7. The compound is very soft and sticky. IF you do any kind of mountain biking these are like the Schwalbe Magic Mary Ultra Soft or the Maxxis Assegai Maxgrip compound feeling.
CON's of the "Blue Dots"-
  1. MY 37 RT Trails barely missed rubbing on the inner felt liner on both sides. The "Blue Dots" rub on both sides on the lower liner near the flaps. I did some surgery to cut the fender liner out and all is well( wish I didn't have to do this). They barely miss the pinch welds behind the liner I cut out. The RT Trails are a hair under 37". I have OEM suspension setup in the front and if you have a collar lift or springs, I am sure you will clear.
  2. These ride great but they feel squishy on braking and acceleration. Could it be that it is C rated and the side walls are softer? Maybe. But you can feel the difference on braking and acceleration on the dive and pitch. I can live with this because I prefer this ride. Some might hate it. Cornering is the same. Feels like the sideways have a little more give.
  3. I drove over some washed out roads overrun with some mud from good ole California rain, and it did great. However, unless I am in 4A I think it does worse on just normal wet conditions. I think this was expected but the RT Trails are not that stellar either.
  4. Price
  5. I have a couple chunks missing from the RT Trails from my last time out on dirt. Being how soft the "Blue Dots" compound is, I think it will be worse off pavement in terms of wear and tear. Only time will tell.
Overall, I would do these again in a heartbeat. My main objective was to get back into a C rated tire but I didn't want to go all terrains or the OEM Bfg's. These give me the looks I want, the ride I want and hopefully it will split the performance off pavement, and on road at a happy medium. I might change my mind later as the miles pile on but I am glad I have a C rated tire option now that I can consider.
Happy driving all!
Saitow
Keller, TX.
Titans, in this case.
Huge fan of Code Orange, but they would clash with the red in the new tires' "BF".
101,389
60,448
Forgotten Image
