Madcowranch
Genetically Modified
OK, got stuck in a big way yesterday in some gooey mud. My Pro-Comp 3"x30' recovery strap worked as designed but I hated putting all that yank on one tow hook (had to pull from the front). All I could think of was yanking the frame out of square as MarkT mentioned.
I know using 2 straps (attached to both tow hooks) is one option but how about using 2 shorter straps with a clevis at each end going to the 2 tow hooks on your vehicle, then attaching the other ends to your main snatch strap going to the recovery vehicle (essentially forming a triangle out in front of your vehicle).
The only thing I don't like about it is that the clevis present possible projectiles in case of line failure.
Maybe 2 straps like MarkT is the best option. But you're still using a clevis at each end to hook up, correct?
