Where to buy your Squadron 2.0's / Reflash Update to fix Backlight issue / How the Squadron 2.0 models compare to Diode Dynamics, and Rigid.
Specialtyperformanceparts
I thought it would be a good time to cover any questions someone may or may not have in regard to the software update to the Squadron 2.0's
First, the new Squadron 2.0 lights are absolutely amazing!
In this post I want to cover 4 topics.....
1: What is the update to the Squadron 2.0 backlight issue and how is it done?
2: How do I know if I have the old programming on my Squadron 2.0 models?
3: If I want to buy them, where and what to look for?
4: What are the performance differences between the 3 main contenders with backlights (Baja Squadron 2.0, Rigid Radiance, and Diode Dynamics.)
SQUADRON 2.0 Backlight UPDATE -
What is the update?
The new Squadron 2.0's were released in early spring.
They received power improvements, styling enhancements, and a first for them. Backlights.
Like most light companies now with backlights, they moved to an RGBW type of backlight vs a fixed color.
What this means is. Instead of buying ONE part number with amber backlights and a DIFFERENT Part number with white or red or blue or green backlights. You can select the color of the backlights you want.
It's a simple process to cycle through the colors and set it.
The issue early on, was that the process was TOO simple. This lead to colors cycling on their own when turned on or off too quickly, or when tied into vehicles.
The fix was a simple reflash to the unit that just adds a couple more steps so the lights don't cycle on their own and get colors out of whack like a rainbow if you have more than one light.
So in July, Baja started rolling out this process. Every Light pair with a date code of 7/1/26 or later should already have this update applied.
In later July, they started making this a warranty process/mail in, to be able to send lights back that were out so they could be reflashed.
Do I have the outdated lights?
So to be clear. If your box has a date code of 7/1/26 or later. It ALREADY has the latest update. It would not be affected by that.
If your box has a prior date code OR you obviously purchased them prior to 7/1/26 and have an issue with colors changing on their own. You can email [email protected] and request an update.
Again, don't overwhelm them if your date code is past 7/1 or you haven't had that issue.
Where is it safe to buy a set that I don't need to worry about needing to send them myself to be updated?
At SPV, we have already sent all of our stock back to Baja to be updated. Anything prior to 7/1/26 production date wise has been updated and has a sticker on it that says "Reflash 7/1". If it doesn't have a sticker on it, then it has a date code past 7/1/26 and already has the reflash.
Baja Designs of course has also updated any stock they currently have and anything they are continuing to produce.
That said, I can't speak for other vendors, resellers, Amazon, Ebay, etc. However, I can tell you this clear fact. If you purchase your Squadron 2.0 lights from US or Baja Designs. You will have the latest update and be issue free. I cannot say that for any other vendor.
There have been many reports of other vendors and resellers knowing the update had come about and continued to, and still do, send out the older production that needs updated.
This is because of a few reasons. Not all malicious. Either they are ignorant to the fact there is an update and or issue. Or they just don't want to hassle with it, and leave it on you the consumer to handle yourself. There is a 3rd reason and that is this. Many of the smaller resellers don't stock their own products and only do drop ships. So they send orders from 3rd party warehouses that have abundant stock. Because of this, there is no way to know if you are getting an updated version or not.
We just want to inform the public on what to do and look for if you are concerned.
So what do you do?
If you purchase from us direct or Baja direct. You are covered with nothing further to do. You will have the latest update. If you want to purchase from another reseller or vendor, be sure you are clear about verifying that you are getting the latest update. Either a production date past 7/1/26 or that have verifiably been updated. If you don't ask, you won't know. So be careful just making direct online purchases on websites, Ebay and Amazon without first inquiring.
As we found out about this, we had been helping any of our customers affected by it through the process.
What happens if you do get an outdated set of lights?
You will just need to follow the procedures above and contact Baja Designs to file a warranty repair.
How do the new Squadron 2.0's compare to the Squadron 1.0, the Diode Dynamics SS3 and Rigid Radiance?
We put together a cool collage with the data specs for each light set here below. This helps with a side by side reference.
So lets get into the meat and potato's...
As you can see. The Rigid Radiance and Scene lights also have an RGBW backlight which you can change. The Diode Dynamics SS3's have a fixed backlight in choice of amber, red, blue or white.
Next, lets get into the patterns.
The Radiance and Radiance Scene have either a wide "Scene" pattern. Or Wide "SPOT" in clear lens only.
The Diode SS3 comes in the following patterns - Wide, Spot, Flood (Which is diffused so in comparison to Baja, they call theirs a "SCENE" in the diffused), Driving, and Combo (Which is half the flood and half the driving pattern). You can also select yellow or clear lenses and can change them out to other colors or patterns.
The Baja Squadron 2.0 comes in the following patterns - An updated Wide Cornering (In comparison to the Diode probably a cross between the driving and Fog Pattern), Spot, Scene (Which is diffused like Diodes Flood) and Combo (Which is half the wide cornering and half the spot). You can also select yellow or clear lenses and can change them out to other colors or patterns.
Next, lets get into the power.
The Radiance SCENE is rated at 2,970 Lumens
The Radiance is rated at 2,180 Lumens
The Diode Dynamics has 3 levels - Sport at 1,520 Lumens, Pro at 3,000 Lumens and Max at 3,500 Lumens
The Baja Squadron 2.0 has 2 power levels - Sport at 3,200 Lumens and Pro at 5,921 Lumens
We also added the Squadron 1.0 in the list for reference so you can see how much the 2.0 models improved over them. The Sport was at 3,162 Lumens and the Pro was at 4,095 Lumens.
Next, lets get into the price. (As of the time of this writing)
Rigid Radiance (Includes a harness)- $349.99
Rigid Radiance Scene (No Harness) - $319.99
Diode Dynamics SS3 SPORT (No Harness) - $279.95
Diode Dynamics SS3 Pro (No Harness) - $399.95
Diode Dynamics SS3 Max (No Harness) - $599.95
Baja Designs Squadron 2.0 SPORT (No Harness) - $249.95
Baja Designs Squadron 2.0 Pro (No Harness) - $436.95
(For comparison sake, The once above do NOT include a generic harness except for the Rigid Radiance model. Baja has the same Squadron lights WITH or WITHOUT an included generic harness. With a harness is $50 more than the 2 prices listed above. So $299.95 and $487.95 respectively. The reason I am referencing this down here is for a better apples to apples comparison, as all but the one Radiance light pair do not have the option aside from buying it separately)
So you can check out this comparison below and then we can move on down below.
We also have a link here where you can see all these specs and compare all the light makes and models in one place on our site -
Next, lets get into the price and power levels as to how these major players compare..
SQUADRON SPORT 2.0
If you looked at the lumen counts above with the Squadron Sport putting out 3,200 lumens for $249.95.
Its closest comparison is the Rigid Scene at 2,970 Lumens for $319.99 or the Diode Dynamics SS3 Pro rated at 3,000 lumens for $399.95
In comparison, you can do your own math, but I think in this price range and output. We have a clear winner with the Squadron 2.0 Sport at $249.95
That's a clear $70 to $150 LESS than the Radiance Scene or SS3 Pro and still higher lumen count.
SQUADRON PRO 2.0
If you looked at the lumen counts above with the Squadron PRO putting out 5,921 lumens for $436.95.
Its closest comparison is the Diode Dynamics SS3 MAX at 3,500 Lumens for $599.95
In comparison, you can do your own math, but I think in this price range and output. We have a clear winner with the Squadron 2.0 PRO at $436.95
That's a clear $163 LESS than the SS3 Max and near double the lumen count.
Conclusion -
These are your top 3 brands.
All 3 are great. So there is no reason not to purchase anything from any of these 3. However, like all brands. They make improvements and come out with new products that move the bar. Over the years, the bar hasn't really move or jumped in massive amounts... until now with the Squadron 2.0. To go from 4,095 Lumens to 5,921 Lumens and keep near the same price point? That's astounding, it it deserves recognition.
So while we carry all 3 brands and are an ambassador to all 3. We can tell you that while you can't go wrong with any of them. I think Baja Designs won this battle this time. I'm sure in the future, we will be talking about a new battle and someone else will take the prize. Until then, congrats to Baja Designs on the new Squadron 2.0. Setting higher standards and reaching new heights!
If you would like to see a deeper dive into the Squadron 2.0, you can watch the video below. In the video we do a full demonstration between the Squadron 1.0 and the Squadron 2.0.
If you have any questions, you can email us at info @spvparts.com or call 317/934/6778
You can also check out all the Squadron 2.0 kits at this link below -
Thanks for the detailed breakdown. Given the 2.0's are slightly larger, are they blocked out at all by FORD logo?
Hey there!
No, it really doesn't change too much about the way they fit back there and their interaction with the grille. They are only less than 1/4 of an inch larger in height/width. We can even put LP4's behind the grille. The Squadron 2.0 lights still will sit nicely below the FORD logo, as seen in the pic below:
Please let us know if you have any other questions or if you need help putting together a custom kit setup.
You can call or text us directly at the number below, as well.
Thanks!
Sidney @ SPV Parts
317. 934 - 6778
@Specialtyperformanceparts Has there been any testing on the lights lumen output on start and after heating up? I have heard that the output can go down as they heat up and wonder what the differences are. Your killer at testing and videos so figured I would ask. Thanks!
We haven't tested that specifically, but I haven't seen any significant or noticeable changes in them while using them in real time. So, if there is any, it would be minimal.
There is a lot you read online. Some is legit, some is people just overthinking and/or exaggerating things. It's often hard to tell one from the other.
In theory, heat can harm circuits and LED's in general, but it usually causes them to burn out prematurely rather than lose power. In turn, any time you turn something like a light on, it's immediately followed by a surge in power that may be greater than the rating stated, but that flash is in an instant. Not something that they would have measured a loss in after it's been running.
On the heat side, they do a very good job of dissipating heat, though.
Please let us know if you still have any additional questions or need help with anything else.
Thanks!
John @ SPV Parts
X5GEE
Will the 2.0 Sports fit in the fog light area? I currently have the 1.0 sports and a S1's.
If you don't have a MODULAR bumper (which is a 24 and up with 37 or R package) then absolutley.
Here are kits for that.
This kit will have the 2.0. We just need to update the photos
This one has 3 Pairs of Squadron 2.0's
And this is the LOWER center Grille
So in your case, if you just wanted to swap the the Squadron lights, and you have the 2.0 set already, we can help you with that. If you email us at info @spvparts.com
or call at 317 / 934 / 6778
John
lthrnck49
For my Gen 2 with ADD Pro V1 front bumper I was looking at adding seven Squadron 1.0s (one amber on each end with five clear between them). Could I fit seven of the 2.0s, or are they too big for that space in my bumper?
Can you measure the opening from side to side on that and let us know? I don't know off the top of my head.
John
lthrnck49
I've got about 24" under there, but think 7 2.0s would be pushing it because of the angled side tubes. I think it best to go down to 6 pods instead. With the increased lumens that should still be plenty. Will reach out to purchase, thanks!
Yeah, I think trying to get 7 of them in there would be really tight, but 6 should fit without any issue.
Just let us know whenever you are ready to get them and we will set you up with everything you need with bundled discounts on it all.
Feel free to call or text us directly when you're ready at 317 - 934 - 6778 and we will get you hooked up. ;)
Cheers!
-Sidney @ SPV Parts
101,289
60,424
HC FabWerks
