Not only did I order a Rack from Jimmy, but purchased a set of Whelen Micro Pioneer LEDs to mount in the front bumper around the license plate.
1) If you live in a state that requires a front plate, The Whelen's are a perfect fit inside the stock bumper.
2) If you don't live in a state requiring a front plate, 4 of the micros would fit perfect in the lower grill opening. That is a ton of light too!
3) The output on these lights is great. They are the whitest LEDS I have seen. I would say 4,000 Lumens per light. The quality is great. Each light has a sealed housing with a gasket to keep water out. The lights also come with 4 separate lenses to change the pattern to each individuals liking.
4) I ordered the bracket as well. It worked and these lights are not going anywhere, but the bracket needed to be milled to make a perfect fit. Otherwise, it is a solid addition. Yes the bracket will work as is, but I wanted it flush.
5) One thing, I have learned, do NOT buy these lights unless you are buying them directly from a Dealer. There are knock offs out there. If you have a problem and send them back for warranty work and the serial numbers do not match your claim will be denied. These lights are only solid though Dealers like WSI! And yes Whelen is the same company that makes Emergency & Airplane lights as well!
*The pic of the Whelen's on the house, is them alone at over a 100ft away!
Some Pics:
Some Pics:
