Wheel Speed Sensor
Discussion in 'Ford Raptor Problems and Questions Forum' started by Dshall2727, Jul 3, 2017.
  1. Dshall2727
    Dshall2727 Member
    7
    Jul 3, 2017
    West Virginia
    I was driving home from work one afternoon, and my hill descent, abs, parking brake and advance trac, warning lights came on. Used the forums to give me an idea of what was going on, plugged into a diagnostic and my right wheel speed sensor is gone bad. Heres where im at now, i have no problem finding the sensor, some are svt specific, but those that arent have options like hill descent tagged with them. Do i just get the svt specific or find one with hill descent etc. Or does that even matter? Do they all function the same as long as i get the correct wheel sensor?
  2. Lifted&slifted
    Lifted&slifted Full Access Member
    51
    4
    Aug 8, 2013
    Same question as the OP...I just replaced both rear wheel ABS speed sensors but the warning lights are still coming on. Anybody have issues like this?
  3. Big Johnson
    Big Johnson Full Access Member
    68
    53
    Dec 20, 2014
    Southern Alberta
    Did you check for codes? Or just throw sensors at it?
  4. Lifted&slifted
    51
    4
    Aug 8, 2013
    I haven’t done a scan to find the exact codes but it sounds like everybody has had a similar problems with the rear ABS speed sensors failing. That’s why I replaced both of them...I guess I need to OBD scan it to see if the front sensors need replacing as well.
  5. Big Johnson
    68
    53
    Dec 20, 2014
    Southern Alberta
    Purely guessing until you have the codes. The guys having problems are guys that are just throwing parts at it and not actually diagnosing it. Sometimes you get lucky, sometimes you dont.
  6. TomD
    TomD Member
    29
    3
    Dec 27, 2017
    The same question, right way to check for codes.
Share This Page
