Wheel Spacers
Discussion in 'Ford F-150 Raptor General Discussions [GEN 2]' started by Jeff-Ohio, Aug 2, 2017.
  1. Jeff-Ohio
    Jeff-Ohio Full Access Member
    47
    475
    198
    Nov 3, 2016
    Cincinnati
    Interested in thoughts on adding wheel spacers to get a more aggressive look since there seems to be complications with going to bigger tires. Any insights that I need to know about wheel spacers?
  2. jaz13
    jaz13 FRF Addict
    1,081
    519
    Jun 15, 2017
    Spacers might give you some of the same problems if you offroad since the tires will no longer tuck into the wheel wells when compressed.
  3. DrippinRaptor
    DrippinRaptor FRF Addict
    1,827
    1,147
    Dec 4, 2012
    Driftwood, TX
    This should be interesting.
  4. Aaron
    Aaron Meme Corps Commandant
    35
    13,164
    7,456
    Jun 13, 2011
    Tucson,AZ
    How big is "Aggressive"?
  5. Idleone
    Idleone Full Access Member
    34
    916
    565
    Apr 3, 2012
    Roseville California
    Ive ran a 2" spacer on my 11 since new. Three raptor runs and no issues at all. Make sure you do your research and get a quality hubcentric spacer.
    ogdobber likes this.
  6. chi_weezy
    chi_weezy Full Access Member
    32
    344
    137
    May 5, 2017
    I considered spacers/hubcentric & wheelcentric bolt on adapters but just went with an aftermarket wheel. I've ran them before on high powered sports cars. You should be fine imo if torqued correctly. Especially for street use
  7. Idleone
    34
    916
    565
    Apr 3, 2012
  8. Jeff-Ohio
    47
    475
    198
    Nov 3, 2016
    Cincinnati
    I would love to put 37 inch tires on the truck, but since that doesn't seem like it's an easy thing to do without issues, I was thinking about changing the stance with some wheel spacers instead of the larger tires. I won't be doing any hard-core off-roodng because I have other off-road vehicles, so probably just street use and some gravel roads for now.
  9. CUSTOMWHEELS4U
    CUSTOMWHEELS4U Supporting Vendor Supporting Vendor
    1,137
    636
    May 19, 2016
    Reno, NV
    The stock offset will give you the least amount of issue with 37's. Pushing them out 2" would put the wheels 3/4" past where a Method wheel would sit making 37's pretty difficult to fit. Anything is possible. Just depends on how sharp you want to turn or how much you want to cut.
    Aaron likes this.
  10. Aaron
    35
    13,164
    7,456
    Jun 13, 2011
    Tucson,AZ
    As Customwheels said, stock offset will give the the least rubbing. Pushing the tires out further is just going to make it worse.
Share This Page
