What seems to be the problem Raptor??
Discussion in 'Ford Raptor Maintenance Forum' started by LEGORAPTOR, Jul 25, 2011.
  1. LEGORAPTOR
    LEGORAPTOR Full Access Member
    31
    479
    11
    May 19, 2011
    Deep South Texas
    So I took my raptor out to the beach this past weekend to try the new M/T tires and had a badass time trying this baby out in the sand dunes. After though when I was on my way back home, Everytime I got to about 80mph I felt the truck shake/vibrate a lot. The I also let the stering wheel go and it would slowly but surely start leaning to the right side. Is it the alignment? Do I have to get tires balanced again? Was is during the crazyness of my off roading that this occured?
    P.S- I'll post pics and vidz later this week of my adventure =P
    THX
  2. pirate air
    pirate air will plunder your booty Supporting Member
    4,253
    1,328
    Jul 11, 2010
    If it shakes its a tire balance problem. I would first check that you don't have mud/sand packed up inside the wheel. If you do, than that could very possibly be your shake. If not, it sounds like the tires need re balanced. The pull could be an alignment issue, low tire psi, or bad tire.
  3. LEGORAPTOR
    31
    479
    11
    May 19, 2011
    Deep South Texas
    Thanks
    I'll check tire balance and alignment this week as well as do another pressure wash on wheels and undercarriage just to make sure theres no sand/mud stuck under there. Thanks a lot.
  4. Rat
    Rat Well-Known Member
    283
    May 23, 2011
    under the 3rd st bridge
    If you were having "fun" you may have bent something ? How is the bed alignment ?
  5. Badrap
    Badrap FRF Addict
    63
    1,357
    344
    Jun 20, 2011
    Haslet, Texas
    Everyone says these things won't do a 100+, BS mine will push 120 but it feels like she is wanting sand and not pavement. It has done this since day one. In the desert she feels fine with no sideways shake or control problems.
  6. DEADEYE
    DEADEYE Full Access Member
    491
    26
    Apr 16, 2011
    MN
    DId you put new rims on with the M/T's ? Check the weights , tape weights ? It ahould be almost impossable with out noticeing when you did it ,but you could have knocked a weight off . I would take it back to where you bought the wheels or had them mounted.
  7. whtrapta
    whtrapta Ostrich Wrangler
    27
    5,489
    911
    Jan 17, 2011
    Bolivar/Springfield, MO
    Sounds like tire weights. 100+? I put mine on the dyno and as soon as I hit 100 power was cut. The fastest I hit was 102
Share This Page
