Warranty Compliant Winch Options
Discussion in 'Ford F-150 Raptor General Discussions [GEN 2]' started by TurboTJ, Mar 27, 2020.
  1. TurboTJ
    TurboTJ Full Access Member
    155
    81
    Apr 19, 2019
    Denver, CO
    I am looking for ways to mount a winch without creating a way for a warranty claim to be denied. The only option I’ve come across is the Warn Ascent bumper which appears to leave the stock intercooler in place (though with reduced airflow most likely). Is anyone aware of a way to mount a winch without effecting the warranty (by relocating the intercooler)? Do any front mount intercooler kits provide their own warranty? Has anyone installed the Warn Ascent Bumper?
    All but 1 option I’ve seen require the intercooler to be relocated. Typically when changing intercooler size, you would want to tune the truck. I believe that both the Intercooler change and the tune can and will be used to deny a warranty claim related to the powertrain.
    I’ve had more than my share of warranty claims and in the age of Ford denying everything they can, I would like to give them no excuses to avoid fixing my truck.
    Thanks in advance for the help!
  2. TXRaptor
    TXRaptor FRF Addict
    1,475
    677
    Sep 15, 2010
    Increasing the size of the IC does not require a tune and a tune does not require a larger IC. They are complementary to each other and often bought at the same time, but you can certainly do one without the other. I have not heard of a larger IC being used as a reason to deny a warranty claim, but I guess anything is possible.
    I know this does not answer your winch question, but it might help you find a way around your dilemma.
    Troutrad and TurboTJ like this.
  3. TurboTJ
    155
    81
    Apr 19, 2019
    Denver, CO
    I wasn’t aware of that. I figured the larger IC would cause some major changes to fueling maps but I guess lots of the time the ECU runs in closed loop so who knows.
    Maybe that will be my plan - relocated IC with an ADD bumper/winch combo and no tune. Do you think that would safe from a warranty perspective? Would I throw CEL’s?
  4. nfsraptor
    nfsraptor FRF Supporting Member Supporting Member
    185
    74
    Nov 7, 2018
    SoCal
    Could always go with a hitch mounted winch you only take out if needed. I personally am looking in the the RPG bumper that has it in the rear bumper under the plate. You can also look at swarfworks I believe theirs doesn't require IC relocation and fits in the stock front bumper it's the only one I know they doesn't relocate.
    JP77, TurboTJ and Swarfworks like this.
  5. Swarfworks
    Swarfworks FRF Supporting Member Supporting Member
    132
    163
    Nov 30, 2016
    Michigan
    Howdy. So my front one does require you to change out the intercooler. Which if your gun-shy about that and warranty issues, I totally understand. On both my ‘17 and ‘19, I’ve never had the dealer say a word about it. And haven’t heard of anyone fighting with a dealer about it. But it could happen. I wouldn’t say that you need a tune if you upgrade the ic.
    You could always do a rear winch. Just have to relocate the spare instead of the intercooler. But pretty sure they can’t void your warranty by doing that!
    TheClaw, WTFOT, TurboTJ and 2 others like this.
  6. Blues Cruz
    Blues Cruz FRF Supporting Member Supporting Member
    Mar 10, 2019
    Indiana
    Who makes the one for the rear?
  7. WTFOT
    WTFOT Member
    11
    3
    Dec 16, 2019
    Thomasville, GA
    I like that rear mount option. How makes it, Swarfworks?
    Swarfworks likes this.
  8. Swarfworks
    132
    163
    Nov 30, 2016
    Michigan
    Yes sir.
    TXRaptor and TurboTJ like this.
  9. jimmyjamm
    jimmyjamm Member
    34
    21
    Dec 12, 2019
    Bend, OR
    Buckstop makes a winch bumper that provides even more flow area to the IC, I have one on my Raptor.
    https://www.buckstopinc.com/classic-1.html
    The bumper is aluminum with the winch mount being steel, so it isn't that heavy. If you don't want the grill tube you can order without.
    johndjmix and TurboTJ like this.
  10. TurboTJ
    155
    81
    Apr 19, 2019
    Denver, CO
    This is exactly what I was looking for! Though I prefer the looks of the stealth fighter, this one looks practical and keeps Ford from trying to deny warranty work.
    How do you like it? Which winch did you get? Is your front camera completely blocked?
    Thanks for posting!
Share This Page
