Wagner Intercooler Installation
Discussion in 'Ford Raptor Engine Discussion and Performance Mods' started by RubyRaptor, Apr 9, 2020.
  1. RubyRaptor
    RubyRaptor Member
    10
    16
    Apr 9, 2020
    Queen Creek, AZ
    I also posted this under the 0-60 thread, but thought I would add it here too:
    A quick update providing some performance details. I have been using an app for years called Pocket Dyno on my iPhone. While it is no Dragy, it's been consistent enough for me and it's $free.99.
    I did 3 back to back runs, and these are the highest 0-60 acceleration numbers from each. I used Sport mode, 4A, and launched from about 2k RPMs for each run. My truck is a completely stock SCREW 19 with the exception of the mods listed below and 91 octane.
    S&B Intake only: 5.26 seconds
    S&B Intake and Wagner IC: 4.99 seconds
    S&B Intake, Wagner IC, ORA550 Tune: 4.69 seconds
    For informational purposes the times for the latter configuration are as follows: 4.75, 4.78, 4.69. I am really liking the consistency. These runs had about 2 minutes of driving in between, so they were not one right after another, and ambient temps were around 60 degrees.
  2. peavey02
    peavey02 Member
    44
    15
    Mar 13, 2019
    NC
    Does the Wagner intercooler keep the fans?
  3. Raptor911
    Raptor911 FRF Addict
    4,252
    1,670
    Aug 9, 2012
    Ashburn, VA
    I am pretty sure this ic keeps the factory fans. You can see them in the pics the op posted.
    peavey02 likes this.
  4. TRMFAM
    TRMFAM Full Access Member
    89
    74
    Feb 23, 2020
    Bartlesville, OK
    Great job...thank you for sharing! Please let us know the tuner's thoughts as well...
  5. Wojciech Gierczynski
    Wojciech Gierczynski Full Access Member
    211
    73
    Apr 4, 2020
    Illinois
    I was looking at CVF Intercooler but i also noticed it would have gap around shroud area. I wanted something that only sits in stock location and ended up going with Mishimoto. It came with rubber grommets around intercooler which touch and make tight seal around shroud area (actually overlapping the shroud on the outside). I heard different things about Mishimoto quality but looking closely at their product I really dont see nothing wrong with it. Hopefully will last. It has exactly same staggered design as CVF does.
  6. Kashoggio
    Kashoggio Lives in a van down by the river.
    430
    427
    Jan 28, 2018
    Looks like that’s some window weather stripping glues on to that thing
  7. Wojciech Gierczynski
    211
    73
    Apr 4, 2020
    Illinois
    Actually no. Intercooler has aluminum strips that run on each of the sides and on top and they are welded to the ends and the rubber grommets slip onto does strips (rubber grommets also have metal strips inside of them so you can actually clamp them down if they become loose. You can see it in the pic how the grommet goes around the shroud and the weld on the side of the intercooler for this aluminum strip that grommet sits on. Like I said looking at this intercooler I dont see nothing wrong with it or quality of all welds etc. Since its made from same exact 6061 aluminum as all other intercoolers I am beginning to think that people saying that will fall apart among other bad assumptions never seen one in person and compared it to others. I am beginning to think that its based on assumption because friend of the friend who heard from friend of another friend said it.
  8. RubyRaptor
    RubyRaptor Member
    10
    16
    Apr 9, 2020
    Queen Creek, AZ
    Sorry I’ve been off the forums for a bit.
    Yes it does. Fans work just like stock.
    Changed over to the MPT Tune. With the 91 MPX I’ve timed multiple 0-60 runs under 4.6 seconds, to include one at 4.49. We hit 111 this week in AZ and the IC is still doing a good job keeping temps...reasonable. Only so much you can do when the ambient temp is so high, but during WOT you can watch the charge air temp drop pretty rapidly. That’s a good sign in my book.
  9. chi_weezy
    chi_weezy Full Access Member
    34
    456
    191
    May 5, 2017
    OP I’m installing the ADD pro bolt on bumper when I get my truck, how long extra do you think this thing takes to install after the bumper removal?
Share This Page
