Oggie
Ditto. Thanks for flagging this. Will call my dealer as well.Interesting! I have the same comment. Thank you for the heads-up. Must be a mistake. Going to talk to my dealership as well.
Thank you!
Thank you!
What? 801a shows the appliqué.If you ordered the 801A package it is part of that package that is why it shows deleted.
Do you guys know if you can add the rear appliqué later via aftermarket?This must be a Ford mistake. According to the build and price page, the 801a package *includes* (and doesn’t delete) the appliqué.
EXTERIOR
• Tailgate Appliqué "FORD"
• Forward Sensing System
• LED Projector with Dynamic Bending Headlamps
if it's like the Gen2 it's a completely diff tailgate.Do you guys know if you can add the rear appliqué later via aftermarket?
What mark said. By default the raptor comes with the appliqué so you have to go out of your way to delete it. Tons of post of gen2 guys looking to swap tailgates. The appliqué makes the raptor unique. Remove it and you are just like every other f150.Do you guys know if you can add the rear appliqué later via aftermarket?
This isn't a mistake those are the accessories u can select technically but long as it shows correct on the picture preview and listed under packages ect it'll be correct. The image is what your truck will look like.This must be a Ford mistake. According to the build and price page, the 801a package *includes* (and doesn’t delete) the appliqué.
EXTERIOR
The problem is that Tailgate Appliqué "FORD" Delete, which shows up on my VIN-specific page, isn’t an accessory I selected and wasn’t on my preview order.This isn't a mistake those are the accessories u can select technically but long as it shows correct on the picture preview and listed under packages ect it'll be correct. The image is what your truck will look like.
Thanks for the link. The good news is my Bronco shows in production, bad news is my Raptor hasn't been assigned a vin. I guess one out of two isn't bad.
just need the order # and VIN
