dabomb4ever
I recently took my truck in for a window tint and ceramic coat. After I received the the truck I noticed the rubber piece that sits up against the window was pulled out a bit on the other side, where it meets the plastic exterior. It was very noticeable because it was in my line of sight when I look at the side mirror. Upon further inspection I noticed 2 vertical scratches exactly 3/4" apart, perfectly symmetrical, which turns out to be DEEP scratches in the exterior of the window down almost the entire length. After talking to the installers, they tried to convince me that it didn't occur during tint, because that's only on the interior of the window. I agreed, and incorrectly jumped to the conclusion they must have tried to remove the exterior plastic during ceramic coating. So they quickly fast forwarded through an 8 hour of footage in about 2 minutes to show me they didn't remove it, they used masking tape. I searched the forums and am aware of dirt/sand getting stuck in between the rubber and the glass which could cause this, and they tried to tell me it was likely there before and not noticeable until the tint was applied. Which all seemed reasonable. Except when I circled back to the fact that I noticed the damaged rubber piece and plastic trim damage before the scratches, that had nothing to do with tint making scratches in the window more noticeable. Sand and dirt wouldn't damage the trim, and would likely move around, these scratches are perfectly straight.
The only other thing that appeared a bit suspect was that they mentioned the car was completed at 8pm that night. I also knew that because I was going to try to catch them that night (about 2 blocks from my house), kept getting the notifications from the ford app of the door opening, and walked down there at 9pm to check the status and ask when to pick up. However at 9pm they were all locked up. And I went to my ford security log and saw tons of activity up till that point when it stopped (8:10pm) opening the door every few minutes, which would be expected when they are working on it. After checking it again today I noticed that randomly at 11:13pm the door was opened. Then no more activity until 10am the next morning. It seems suspect that the door was opened 3 hours after they said they finished and they were all locked up. But doesn't explain the damage. Mileage didn't change as if it was driven anywhere.
Does anyone know of any tool or procedure done wrong which could have caused this? Maybe magnets stuck on the window to hold the tint? Or something thin that could have gotten sucked in and stuck. It has to be something that not only caused deep scratches, but also caused the rubber to bubble up from the plastic trim. It is also perfectly aligned and symmetrical, like it didn't move the entire time the window moved up or down when the scratches occurred. And the scratches are deep, real deep in the exterior of the glass. If I can narrow something down I can ask to see their footage again.
Below are the photos, sorry its very hard to capture the scratches with reflection, but it is deep enough to catch a fingernail and aligns perfectly with the trim damage.
Thanks in advance for the help.
