Ventilated Seat Cleaning
Discussion in 'Ford Raptor Cleaning and Detailing Forum' started by VinceC, Aug 8, 2019.
Adam's Polishes
  1. VinceC
    VinceC Member
    30
    8
    Apr 16, 2019
    Alabama
    This has probably already been covered, but I haven't been able to find it in this forum.
    What does everyone think is the best way to clean the ventilated seats? I tend to get stuff stuck in all the little holes and it's tough to clean. I have been using a plastic dental tool and individually going through every whole that is stopped up. Is there a better way?
  2. TripleE44
    TripleE44 Member
    31
    39
    30
    Nov 6, 2012
    I've had some good luck using a vacuum with a really small tip, and it gets most of it. You'll still have to go back with something small like you've been using though on some of it.
  3. goblues38
    goblues38 FRF Addict
    1,001
    858
    Oct 27, 2018
    STL
    yeah....i had a chocolate chip fall off a granola bar...not I have a spot of 4-6 holes with chocolate pluggung the holes.
  4. VinceC
    VinceC Member
    30
    8
    Apr 16, 2019
    Alabama
    I got a three year old.. so we end up with stuff everywhere:)
    bushman likes this.
  5. SD64
    SD64 Member
    43
    19
    Apr 20, 2019
    USA
    I use a stencil brush to clean the perforations which you can get at Home Depot for a couple bucks. Spray a small amount of cleaner into the brush head and work in small circles. Your cleaner should create a lather and you can apply a little pressure to get into the perforations. Wipe the surface with a towel and use a vacuum to suck out any excess moisture.
    The key is using a small amount of cleaner so you don’t create a mess. If you use too much you can turn the seats on to dry it out.
    VinceC likes this.
  6. Ryan Soto
    Ryan Soto Full Access Member
    65
    12
    Oct 16, 2019
    Illinois
    Toothpick lightly and vacuum is what I do!
  7. bunkisland
    bunkisland Full Access Member
    69
    9
    Jan 17, 2016
    I have a 14 YO and end up with stuff everywhere.
  8. bunkisland
    69
    9
    Jan 17, 2016
    Good tip.
Share This Page
