If a full time hub was available for the Raptor would you upgrade?
  1. Yes, in a heartbeat
    32.3%
  2. No, there is no reason
    12.0%
  3. Maybe, once all the details are finalized
    48.1%
  4. Don't care either way
    7.6%
Sponsored By: Fox - Redefining Ride Dynamics
  1. Squatting Dog
    Squatting Dog FRF Addict
    8,616
    4,098
    Jun 1, 2011
    Kansas City, MO
    I wanted to put up poll to gauge the interest in an upgrade IWE.
    What I am planning it to strip all the guts out of the IWE removing the spring/vacuum parts/and flimsy 1/4 gear ring with a solid gear ring. This would cause the front axle to be locked at the hubs and no more shearing/rounding the teeth off the IWE gear ring. There would be more noise, loss of fuel economy (figure 1 or 2 mpg), and wear on tires and drivetrain.. The benefits would be fully locked hubs, no slipping or clunking, no vacuum lines, vacuum solenoids, or check valves to fail..
    I do not have final design of the uprade IWE yet, I am working on it. I do not know what long term effects to drivetrain or axles. This is just in the idea stages right now..
    JP7 and khcdave like this.
  2. CoronaRaptor
    CoronaRaptor FRF Addict
    11,545
    2,638
    Dec 17, 2012
    So, you're planning on having manual locking hubs, right?
    Squatting Dog likes this.
  3. Yukon Joe
    Yukon Joe FRF Addict
    40
    18,308
    11,562
    Nov 16, 2011
    Oak Island, NC
    Count me in.
    Yukon Joe
    Delta Force
    Snoball500 Support Raptor
  4. beemerman
    beemerman FRF Addict
    13,210
    4,196
    May 3, 2011
    Worlds most famous beach
    Here is what I found today. A cracked Iwe. So I think my right axle was engaged the whole trip. [​IMG]
  5. Squatting Dog
    8,616
    4,098
    Jun 1, 2011
    Kansas City, MO
    if I can work it out, right now it is looking like the easiest method would be having the hubs fully locked to the axle shafts and use the transfer case to shift in and out of 4wd.. Less failure prone parts by removing all the vacuum lines and diapraghm that is subject to freezing degrading/tearing..
    You can see after I cleaned all the old grease and particles of actuator gear off that the hub gear DOES take some damage from this issue. The actuator gear is made much softer so it takes the majority of damage. I'm assuming the gear was already slightly beveled so the actuator gear can click right on but it did have some burrs along the gear teeth.
    [​IMG]
    Next we see the difference new to old and what happens to it when you hear the noise. The new gear has a flat edge to the hub side of the gear and you can clearly see that on the old one this has been ground to about a 30 degree angle shorting the gear to the point of nothing more to engage, so with the open diff taking the path of least resistance that half shaft will spin when in 4WD and the other, even though it works, will not do anything. No 4WD..
    [​IMG]
    compared to new IWE
    [​IMG]
    So what I am planning to do is gut a perfectly good IWE removing the guts (spring, vacuum lines, and 1/4" gear) and replacing it with a 1" billet gear to take the place of the vacuum componets. This will lock the hub to the axle not allowing slippage and wearing of teeth of the IWE or axle..
    BigBlueBalls and KaiserM715 like this.
  6. beemerman
    13,210
    4,196
    May 3, 2011
    Noticed the wear on the right side iwe when I took it out. You are correct the iwe wears way faster than the axle. Should work fine to replace the guts with a billet gear or spacer. May not notice too much change in mileage.
    ---------- Post added at 08:42 PM ---------- Previous post was at 08:38 PM ----------
    Years ago when we had manual locking hubs on almost every make,there was a spring that held the gear in place. Similar to what we have now. If you added more horsepower than the setup could take the spring would collapse and you would lose 4x4. I think it was mile marker who made a stronger spring that would overcome this problem.
  7. Squatting Dog
    8,616
    4,098
    Jun 1, 2011
    Kansas City, MO
    Here is a dissected new IWE (I don't want anyone to say i never make sacrifices for FRF)
    Iwe assembly
    5/16th iwe gear that is supposed to hold the power of the Raptor
    This is the spring that is supposed to hold the IWE gear to the hub
    Inside the IWE assembly, this is the vacuum port that gets contamination and causes IWE gear teeth to wear down
    The IWE gear only travels 1/4 inch to engage and disengage 4wd. If you add 1/2 internal splined gear it would effectively lock hub and axle together...
    Hope this make a little more sense, now..
    -Greg (aka squatting dog)
  8. beemerman
    13,210
    4,196
    May 3, 2011
    Oh the humanity. Sacrificing a new gear. My dealer had 3 in stock. Said they sell a lot of them. Paid $102.00 for mine. If you want my old one I can send it too you.
    Hockster likes this.
  9. Squatting Dog
    8,616
    4,098
    Jun 1, 2011
    Kansas City, MO
    I have two shredded IWE of my own...
    Thinking about the spacer idea, would work.. The only issue I see is that one solid piece with full depth teeth would allow full contact to the hub and axle.. This would eliminate any chance of slipping and spread power across the full 1/2" verses just 1/4" of teeth.
    KaiserM715 likes this.
  10. beemerman
    13,210
    4,196
    May 3, 2011
    Yea I am sure it would. Keep us updated. Jack
Share This Page
