UPDATE; Mildew smell in the cabin after it rains.
Discussion in 'Ford F-150 Raptor General Discussions [GEN 2]' started by BangBang, Mar 31, 2020.
  1. Derail
    Derail Full Access Member
    120
    62
    Jan 24, 2018
  2. BangBang
    BangBang Full Access Member
    262
    118
    Apr 2, 2018
    Looks like a simple look at the rear vents won't do. You have to pull things apart to get to the problem, because it might not be seen simply.
    I checked all the door plugs and everything is good with them.
    Checked the passenger side rear vent and it looks good. But, I guess I need to check how it is sealed.
    Drivers side will require pulling the amp and sub. That will be done later today.
  3. Stroked out
    Stroked out Full Access Member
    98
    30
    Nov 23, 2018
    Florida
    I had this problem, my smell was inside the vents. Spray some lysol in the cowl right in front of the passenger windshield. Do that with your ac on outside air. If you run ac constantly in recirc there will be a smell. Turn your ac off a couple minutes before stopping and put it on fresh air. That's what fixed mine, hopefully it helps . GOOD LUCK
  4. Bumpngrind
    Bumpngrind Member
    13
    Mar 4, 2020
    Scottsdale
    Thank u sir
  5. BangBang
    262
    118
    Apr 2, 2018
    Thanks everyone
  6. BangBang
    262
    118
    Apr 2, 2018
    Update
    Rear sliding window is misaligned.
  7. Antho
    Antho Full Access Member
    248
    142
    Apr 12, 2019
    Thanks for the update. That’s a new one for me. Easy fix?
  8. BangBang
    262
    118
    Apr 2, 2018
    Warranty replacement of the rear window.
Share This Page
