up fitter light install 2017 Gen2
Discussion in 'Ford Raptor Lighting Forum [GEN 2]' started by Taube2013, Mar 24, 2017.
  1. Taube2013
    Taube2013 Member
    22
    8
    Dec 25, 2013
    White Lake MI.
    Have not done any lighting cannot find any how to videos on the 2017 wiring harness. Just want to install a light bar on bumper. The owners manual says the 15 amp is the highest amperage most light bars are pulling 20-25 amp do you just simply change the fuse ? And does anyone have the steps to do the light bar wiring? I know this is pretty basic stuff I just have not yet did one any help is appreciated, taube2013
  2. ZaneMasterX
    ZaneMasterX FRF Addict
    1,515
    1,462
    Apr 27, 2014
    Mountains
    Dont burn down your truck...if you cant figure it out yourself pay someone that knows how to do it.
    Relays, in line fuses, yadda yadda
  3. Aaron
    Aaron Meme Corps Commandant
    35
    13,164
    7,457
    Jun 13, 2011
    Tucson,AZ
    Haha holy shit man don't go swapping fuses for higher amperage ones. That's how your truck burns down.
  4. Addictive Desert Designs
    Addictive Desert Designs Supporting Vendor Supporting Vendor
    1,750
    792
    Aug 9, 2010
    Mesa, AZ
    This may help you.
    [​IMG]
    SOAKINRED and TornadoRaptor like this.
  5. Taube2013
    Taube2013 Member
    22
    8
    Dec 25, 2013
    White Lake MI.
    Ok good info so does anyone have walk though ?
    ---------- Post added at 07:29 PM ---------- Previous post was at 07:27 PM ----------
    Thank you ADD so if a ridged 40 inch light bar is pulling 20amps you cannot use because you would be blowing fuses correct?
    ---------- Post added at 07:36 PM ---------- Previous post was at 07:29 PM ----------
    Thank you ADD so a 40inch rds Ridgid light is pulling 20 amp draw you cannot use because you would be blowing fuses correct?
  6. Ironhorse07
    Ironhorse07 FRF Addict
    59
    1,202
    1,668
    Oct 23, 2014
    Central, MT
    I am going to say that from your questions, it appears to me that you are in over your head on this deal. I would suggest finding someone who knows what they are doing to do this.
  7. johnjoemd
    johnjoemd Full Access Member
    200
    119
    Dec 10, 2016
    New 2017 Raptor. 70k
    New Rigid 40" light bar $400
    It all going up in a blaze from a DIY project. Priceless
  8. ISFast
    ISFast FRF Addict
    2,562
    961
    Mar 11, 2011
    Tulsa, OK
    Gen 2 65 amp total compared to Gen 1 85 amp total..... hmmm but more switches in the Gen 2 :Pshyco:
  9. Taube2013
    Taube2013 Member
    22
    8
    Dec 25, 2013
    White Lake MI.
    Upfitter switches request for help!
    Any one that's interested on this subject I found a good post that answers my questions about the light bar installation and the amperage and relays, under the Upfitter switches request for help! post thanks taube2013
  10. Guy
    Guy FRF Supporting Member Supporting Member
    1,120
    653
    Feb 16, 2017
    The answer my friend is not blowing in the wind.
    You will need a hot wire going to the battery with an appropriate gauge and in-line fuse. I'd spec for 25-30 amps and go 10 gauge. Why? Because you can.
    That hot wire will need an in line fuse. It'll power the incoming hot leg of a relay rated for 30 amps. You'll wire the outgoing 30 amp hot leg to the lights. You'll ground the lights to the frame. You'll wire the control hot and negative wires of the relay, one to the battery negative post and one to the hot leg of the upfitter switch.
    If you don't know what I'm jabbering about... stop now and go to a reputable shop.
Share This Page
