MagicMtnDan
Unsprung Weight
This is one of the most critical factors affecting a vehicle's road holding ability. Unsprung weight is that portion of a vehicle that is not supported by the suspension (i.e. wheels, tires and brakes) and therefore most susceptible to road shock and cornering forces. Lighter weight wheels reduce unsprung weight and provide more precise steering input and improved "turning in" characteristics.
Unsprung weight
The following is from Wikipedia: http://en.wikipedia.org/wiki/Automobile_handling
Ignoring the flexing of other components, a car can be modeled as the sprung weight, carried by the springs, carried by the unsprung weight, carried by the tires, carried by the road. Unsprung weight is more properly regarded as a mass which has its own inherent inertia separate from the rest of the vehicle. When a wheel is pushed upwards by a bump in the road, the inertia of the wheel will cause it to be carried further upward above the height of the bump. If the force of the push is sufficiently large, the inertia of the wheel will cause the tire to completely lift off the road surface resulting in a loss of traction and control. Similarly when crossing into a sudden ground depression, the inertia of the wheel slows the rate at which it descends. If the wheel inertia is large enough, the wheel may be temporarily separated from the road surface before it has descended back into contact with the road surface.
This unsprung weight is cushioned from uneven road surfaces only by the compressive resilience of the tire (and wire wheels if fitted), and which aids the wheel in remaining in contact with the road surface when the wheel inertia prevents close-following of the ground surface. However, the compressive resilience of the tire results in rolling resistance which requires additional kinetic energy to overcome, and the rolling resistance is expended in the tire as heat due to the flexing of the rubber and steel bands in the sidewalls of the tires. To reduce rolling resistance for improved fuel economy and to avoid overheating and failure of tires at high speed, tires are designed to have limited internal damping.
So the "wheel bounce" due to wheel inertia, or resonant motion of the unsprung weight moving up and down on the springiness of the tire is only poorly damped, mainly by the dampers or Shock absorbers of the suspension. For these reasons, high unsprung weight reduces road holding and increases unpredictable changes in direction on rough surfaces (as well as degrading ride comfort and increasing mechanical loads).
This unsprung weight includes the wheels and tires, usually the brakes, plus some percentage of the suspension, depending on how much of the suspension moves with the body and how much with the wheels; for instance a solid axle is completely unsprung. The main factors that improve unsprung weight are a sprung differential (as opposed to live axle) and inboard brakes. (The De Dion tube suspension operates much as a live axle does, but represents an improvement because the diff is mounted to the body, thereby reducing the unsprung weight.) Aluminum wheels also help. Magnesium alloy wheels are even lighter but corrode easily.
Unsprung weight
