unknown front end noise vibration 4wd?????
Discussion in 'Ford Raptor Problems and Questions Forum' started by BRAAPTR, Feb 14, 2015.
  1. BRAAPTR
    BRAAPTR Member
    34
    11
    6
    May 13, 2014
    So my truck was making a small noise that almost sounded like my stability control was being activated on my left front wheel. I could feel the small vibration on my feet and the steering wheel. Didnt sound to me like what a bad wheel bearing would sound like And it pulled a little to the left. Its hard to describe a sound over the inter web. But if these lines were a noise it would sound like this.. (.) Small break. The ( ) is a big break in sound.
    _____._____._____. _____._____._____.
    **I should note that this noise started after i put it back to stock perch from top perch.**
    after i heard the noise i notice that my tire ripped the vacuum line in half that goes to my 4wd hub.
    I have extended warranty and the shop replaced my wheel bearing/hub/4wd actuator. its been about a week and its making the same noise it did before.
    I have no idea what it could be and the shop is having a hard time trying to diagnose the noise. Has anyone here had a similar issue that found out what it was?
    Thanks guys!
    -Mike
  2. Yukon Joe
    Yukon Joe FRF Addict
    40
    18,308
    11,562
    Nov 16, 2011
    Oak Island, NC
  3. BRAAPTR
    BRAAPTR Member
    34
    11
    6
    May 13, 2014
    They replaced the actuator. Not sure about a valve? is that the solenoid Up on the firewall?
  4. Yukon Joe
    40
    18,308
    11,562
    Nov 16, 2011
    Oak Island, NC
  5. BRAAPTR
    BRAAPTR Member
    34
    11
    6
    May 13, 2014
    I'll have to look into how to test it. Would that be something that would cause this
    noise?
  6. Yukon Joe
    40
    18,308
    11,562
    Nov 16, 2011
    Oak Island, NC
  7. FordService
    FordService FRF Addict
    1,011
    506
    Feb 17, 2014
    Hi Mike,
    Let's see what I can do to help. What's your truck's model year/mileage? I'll start researching some options.
    Crystal
Share This Page
