UCA and 3’lift
Max FR
France
Hi guys, I just installed the Eibach 3’ coils on low perch and the truck sits way higher than with the stock springs at mid perch. The front is now 1/2 inch higher than the rear. I am going to sort out this by lifting the rear slightly but my question is: with such a lift on the front, are adjustable UCA’s mandatory to setup a correct geometry ? There is a pretty important negative camber now.
Thanks
Pacific Wheel
Reno, NV
Adjustable UCA's will help dial the alignment if it's too far out of spec with OE UCA's. The UCA and axle geometry would remain the same due to the lift though.
