TSB 11-8-12 5.4L Transmission Harsh 2-1 Downshift
pirate air
will plunder your booty
TSB 11-8-12
08/18/11
5.4L 3V AND 6R80 TRANSMISSION - HARSH
COASTING 2-1 DOWNSHIFT BUMP FELT AT OR
BELOW 12 KM/H (8 MPH)
FORD:
2009-2010 F-150
2009-2011 Expedition
LINCOLN:
2009-2011 Navigator
ISSUE
Some 2009-2011 Expedition, Navigator and 2009-2010 F-150 vehicles equipped with 5.4L 3V engine and 6R80 transmission may exhibit a bump feel during a low speed coasting downshift at speeds at or below 12 Km/h (8 MPH).
ACTION
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
1. Install Integrated Diagnostic System (IDS)/Portable Diagnostic Software (PDS) or equivalent and ID vehicle.
2. Reprogram the powertrain control module (PCM) and transmission control module (TCM) calibration using IDS release 74.03 and higher. This new calibration is not included in the VCM 2011.7 DVD. Calibration files may also be obtained at the website.
a. Calibration updates can be viewed from the tech log view screen on IDS after programming has been completed.
NOTE THE TCM CANNOT BE INDEPENDENTLY REPROGRAMMED, REPROGRAM USING THE PMI FUNCTION TO ENSURE THAT ENGINE AND TRANSMISSION CALIBRATIONS ARE UPDATED TO THE LATEST LEVEL SIMULTANEOUSLY.
NOTE IT IS CRITICAL THAT TCM KEEP ALIVE MEMORY (KAM) BE CLEARED FOR THIS PROCEDURE TO BE FULLY EFFECTIVE.
3. Clear TCM KAM and adaptive tables.
a. Using IDS:
(1) Open Toolbox
(2) Choose Powertrain
(3) Choose Reset KAM
(4) Choose TCM
b. Using PDS:
(1) Choose all Tests and Calibrations
(2) Scroll down the menu and choose reset TCM KAM
NOTE
FOR PDS, RESET TCM KAM IS NOT THE SAME AS CLEAR TRANSMISSION ADAPTIVE TABLES, WHICH IS UNDER THE POWERTRAIN - TRANSMISSION MENU TREE.
NOTE DISCONNECTING THE BATTERY WILL NOT CLEAR THE TCM KAM. IT IS CRITICAL THAT TCM KAM BE CLEARED PRIOR TO RELEARNING THE ADAPTIVE TABLES FOR THE TRANSMISSION.
NOTE DO NOT CLEAR THE PCM KAM.
4. Verify that the transmission fluid temperature (TFT) PID is above 175 °F (80 °C). If it is not at 175 °F (80 °C), drive unit approximately 5 Km (3 miles) to reach temperature.
NOTE TFT MUST BE AT 175 °F (80 °C) OR ABOVE BEFORE PROCEEDING TO STEP 5.
NOTE PERFORM ADAPTIVE SHIFT STRATEGY LEARN ON LEVEL SURFACE ROAD.
5. Drive unit to perform adaptive shift strategy learn.
a. Accelerate from a stopped position with light throttle to 24 Km/h (15 MPH) and remove foot from accelerator pedal.
b. Brake very gently to a complete stop (allow at least six (6) seconds).
c. Repeat steps (a-b) five (5) times in the dealership parking lot or similar setting.
d. Accelerate from rest with light throttle ensuring that the 1-2, 2-3 and 3-4 shifts occur at engine speeds between 1700-2000 RPM.
e. Continue to accelerate until you achieve 80 Km/h (50 MPH) or the 5-6 upshift.
f. Brake gently to a complete stop and hold foot on brake for ten (10) seconds.
g. Repeat steps (d-f) three (3) times.
NOTE
SEVERAL DAYS OF DRIVING ARE REQUIRED FOR THE TRANSMISSION TO FULLY ADAPT.
NOTE
PLEASE ADVISE THE CUSTOMER THAT THIS VEHICLE IS EQUIPPED WITH AN ADAPTIVE TRANSMISSION SHIFT STRATEGY WHICH ALLOWS THE VEHICLE'S COMPUTER TO LEARN THE TRANSMISSION'S UNIQUE PARAMETERS AND IMPROVE SHIFT QUALITY. WHEN THE ADAPTIVE STRATEGY IS RESET, THE COMPUTER WILL BEGIN A RE-LEARNING PROCESS. THIS RE-LEARNING PROCESS MAY RESULT IN FIRMER THAN NORMAL UPSHIFTS AND DOWNSHIFTS FOR SEVERAL DAYS.
WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT : Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
110812A 2009-2010 F-150, 1.0 Hr.
Navigator: Reprogram The
PCM And TCM, Includes
Time To Perform Adaptive
Shift Strategy Learn (Do
Not Use With Any Other
Labor Operation)
DEALER CODING
CONDITION
BASIC PART NO. CODE
RECAL 42
